Ford 9" question a little long
00gyrhed
Some of you know I have been fighting a project and every time I turn around there is something new that is wrong. There have been a lot of returned parts and messed up weekends.
AT THIS POINT I HAVE BECOME KIND OF PARANOID AND ANYTHING A LITTLE OUT OF THE ORDINARY I START WONDERING WHAT IS GOING TO GO WRONG NEXT.
This question involves my 9".
I set it up myself and the drive pattern is beautiful. slightly under center and big and broad right in the center of the tooth. Actually one of the best patterns I have ever seen. No doubt in my mind it was good to go.
Problem was the coast pattern just looked a little odd. lower down in the toe than I thought it should have been and certainly not nearly as cleanly centered.
However that all being said the gear set came with a pattern marked on it and mine was almost identical.
I decided to leave it there since the last .002 shim change moved the drive side from a very poor pattern to this nice pattern and I had no way to drop .001 out of the shims. I was at a measured .011 and had no shim that measured .010, which seemed really odd but since its all relative and I was using the same micrometer I decided to install it and run.
Issue is it makes a high frequency whine. Not loud, and sometimes non existent in coast. Drive is dead quite. Now I basically have a new engine transmission and new bearing all the way through fro transfer case to the wheel. This whine does not have the frequency of normal gear noise, but I am not ready to say its not since my coast pattern wasn't what I expected it to be. There are a world of things it could be including the transfer case and I am not inclined to pull anything right now.
I read several things on the internet while trying to find some pictures of pattern that some of the mustang people recommend 25 in pounds of preload on the pinion I set mine up inside the ford specs I found but some of the mustang guys attribute this whine to too low a preload. I don't like to set up a new bearing with 25 in pounds of preload. Also when I torqued down the pinion nut to the 175 ft-pounds ford recommends I had way more that 25 in-pounds. I tore the whole thing apart examined everything, everything measure our right and all the races were properly seated, so I threw in a new crush sleeve and did it again working up to 150 ft pounds to get 10 in-pounds.
What I have
1. ARB
2. 4.33
3. 0.011 pinion shim
1. 10 in-pounds of preload on the pinion bearings
I am going to drive it a while but I would really like a little input especially about the mustang crowd using 25 in-pounds.
It is quite possible that this has always been there and I just didn't hear it over the NP435, and SS.
Timmy390
Conway, AR
Why are you using a crush sleeve? Get a solid spacer and same time and trouble.
What brand of gears? Some gears are noisy.........Mine are cheap and I'm sure they make noise but between the radio and the cheery bombs, I don't hear a peep out of them.
Tim
Rustytruck
Did you check the run out on the back face and diameter of the ring gear and make sure they were running tru before setting the gear mesh? What was the backlash in the gearset once you torqued everything down?
cs_88
If I remember correctly, the Bad Shoe video called for 15 to 29 in. lbs. of pinion preload. I set mine at about 21.
Carrier bearings were set with .010" of case spread.
broncnaz
As was said a lot of aftermarket gears are noisey. I'd want the pinion preloaded a little more. Remember the oil seal will account for some of the drag as well. Usually around 3-5 in lbs but I have heard of more.
