Ford 9” Rear-End Housing
Tjboriack
@74LUBR
College Station
I am in the process of upgrading to a new carrier with a new third member and 31 spline axles. I have everything torn down and while getting it cleaned up to go back together I notice that the left side has quite a bit of damage where the axle bearing should ride. Looks like someone beat the crap out of it with a chisel trying to remove an older race or something. Older axle set up I removed had the inner seal then the bearing on the outside, the new one has the seal on the outside and I am not sure I will be able to get the seal flush enough to keep from bending the retainer.....
Not sure how to share pictures on this forum.....
Thoughts.....
Thanks,
Tom
.94 OR
Willamette Valley, OR
I'm doing exactly what you are attempting to do.
The seal goes inside the tube and rides on the axle shaft inboard of the bearing retaining ring and the sealed bearing.
I can pull some quick pictures if you need them.
fordguy
Have to be a contributor to post. A mere 12 bucks.m
Factory has the seal in the tube and runs a sealed bearing. Upgrade removes the seal, runs a wet bearing, and the seal is the retainer.
Hard to say. Kinda need to see it. Housing ends can be replaced but they must be true. They are jigged before welding.
At this point you also need to think about how much work you are going to put into the stock housing and just upgrading the housing. With the new upgrades the stock housing will be the weakest link.
Timmy390
Conway, AR
Need pics for sure.....
As stated factory seal is not used with the 31 spline upgrade as the bearings (set 20) are wet with the 31's. The bearing cup needs to be smooth and without damage to seal correctly.
If the cups are just pitted and have gouges and dings you could use "pig putty" (known as epoxy putty) and fill in and sand smooth. I've done it........
On the other hand....you can change the cups....I've done that too.....As stated they make a "jig" for this. I kind of did it my own way without a jig taking a ton of measurements and tack welding the housing to known flat level surface and using the center section and axles with the old undamaged bearings as the jig.
It cam out great but lots of room for error.....Cost me $150 vs the $600 for a new housing.....
Tim
Apogee
Tangent, OR
I put new housing ends on a '76 F150 9" going under my EB, and it wasn't that much work , but did require a welder and alignment bar. Fortunately for me, I have a welder and a friend offered up his alignment bar, so $65 for a pair of new housing ends from Quick Performance and half a day's worth of work to chop it down, measure 60 times and then weld it back up, and it was good to go.
.94 OR
I made the assumption from the first post that the OP was upgrading from a 28 to 31 spline axle.
The ones I bought from Tom's look identical to the factory 28's.
There are 2 main ways of sealing the axles.
Inner seal and run a sealed bearing (stock bronco and many car).
No inner seal, wet (non-sealed) bearing, outer seal. This was also a production way of building the 9". I have an early 80's F150 that is this way. The tapered bearings are this way, higher axle load rating.
OP was mentioning concerns about the outer seal actually sealing. Sounded like he did the tapered bearing upgrade.
Tjboriack
Tjboriack
@74LUBR
College Station
Correct I have concerns of the new style bearing and seal seating far enough into the housing because of previous damage. If they don’t seat all the way I have concerns of bending the retainer plate and causing alignment issues with the disc brakes I added.
Thanks for the shout out Billy. Glad you like it.
They're a nice piece of work for sure.
Tjboriack, your first pic (thanks for becoming a contributor so fast by the way!) looks halfway decent, but your second one is surely buggered up good.
While I'm not 100% sure that the area the seal rides on is in that bad a shape, it really does not seem to take much of a blemish to cause a leak on either type of seal.
That said, you could try some sealant around the outside where the new seal will ride. It's cheap and easy and quick and might work. If it does, you're golden. If not, well you tried and then you can spend some extra money on fixing or replacing the old housing.
The ends are readily available as was said. Even to the tune of machined billet ends at a higher price point of course. Regular ones are very affordable for the parts at least. But a relatively fair bit of work to get them in.
Depending on how much work you can do yourself the cost might rise up to the point that a new housing is actually a better deal. More housing for less money...
So you still have options. I'm kind of doubting the extra sealer will help in your case, but it might be worth the shot if you can be sure that you won't bugger up the new seal by putting it in. If any of that surface surrounding the seal is nicked or scratched too, I would not try it. Instead I'd go for the new stuff.
For your brakes, the brake backing plate should not be the same as the retainer. Your retainer might be standing off somewhat, but the brake backing plate (or caliper bracket if discs) should have a hole larger than the bearing just enough to slip over and fit flush up against the housing end.
Then the bearing retainer slips up to the outside of the caliper bracket. Guess it depends on the mounts you have, but you can test fit everything to see how it's going to work.
If you have to make a spacer plate to fit between a retainer and the bracket to hold it tight, that might not be too much trouble to get done.
Good luck.
Tjboriack
Tjboriack
@74LUBR
College Station
Thanks Paul. The information is greatly appreciated. I may try to see if it will seal as suggested, if it doesn’t then I will most likely come back and put a new housing in.
In regards to the disc brake baking plate that was between the bearing retainer and the housing plate - you would still use that as well? Even though the new retainer has the thickness of the previous retainer and backing plate?
Thanks,
Not sure I'm following what you're saying. Do you mean the drum brake backing plate? If so, no it does not get reused and would probably interfere with the caliper bracket.
Some (most?) disc caliper brackets bolt to the backside of the housing end (outside of the bearing and traditional drum backing plate area) and not effected, or have an effect on, the retainer plate and bearing.
A bearing retainer of a different thickness does not have any effect on brake spacing either. But the new Set-20 tapered roller bearings sit proud of the housing end, where the original was more of less flush with the end.
So removing the original backing plate and adding the thicker bearing does change the way the retainer clamps against the new bearing.
Is that what you were asking?
In my opinion this increases the preload on the bearing and so the retainers should be designed specifically for this type of application. And I don't think they are. It's not necessarily correct, but thousands of people have just used standard retainers and simply tightened the fasteners as usual, deforming the retainer plate around the bearing.
I don't like it, but have never heard of a bearing failure due to this added force, so have no real argument against it. Other than I just don't like it!%)
Tjboriack
Tjboriack
@74LUBR
College Station
I installed the disc brake conversion (from Wildhorses) in May 2019. I have attached a picture of the spacer/bracket I am talking about. It originally rode between the bearing retainer and the housing bracket (with the t-bolts through it).
Just trying to determine if I still use this or not since the new retainer has the same thickness as the old retainer and this plate attached.
Thanks,
If the spacer is for the disc brakes then I would continue to use it. If it was correct for your previous setup, it should still be. At least as far bearing retention is concerned.
But of course double check the rotor spacing after the install to make sure nothing has changed in that regard.
I am really not familiar with the spacer personally, but it looks to be to take up the space from the now-missing drum brake backing plate.
If that's the case I don't see any reason to remove it. In fact I see good reason to retain it. Looks like the same amount of spacing you'd need just for swapping over to the Set-20 bearings. That alone should be worth keeping it.
As mentioned, the thickness of the new retainer changes nothing because it's "outside" of the bearing. But the spacer, being "behind" the retainer, between it and the housing end flange spaces things out, theoretically to the proper level for bolting to the housing end.
In fact I can see a precedent for adding more if this one alone does not space the retainer far enough out to clear the new bearing.
The axle and bearing should stay seated fully into the housing end, with no in-and-out movement. But not with so much tension on it that you have to bend the retainer over at the bolts.
I'll see if I can get any confirmation or denial of what I've said and report back.
Timmy390
Conway, AR
Those end caps are beat the heck out of for sure. See if you can save them. First step check them for being round. Mine were oblonged due to a failed bearing at see point in its life. If they are round try and clean up the beat up area. Then geese the inside of the cup and slide the axle in and verify it fits properly. Then remove the axle and look at the grease and see where the seal on the set 20's is riding. It it's smooth and the cups are round it should seal up
Tim
Keep the spacer for sure. It's indeed there primarily to make up for the missing factory drum backing plate.
And it was mentioned already I think, but definitely do what you can to clean up any nicks, scratches or blemishes that might be anywhere near the seal before you install.
Sealer or not, a nasty enough defect could cause it to leak no matter what you try. And you definitely don't want to nick the seal, because it's not available separately like the old one. Has to come with a new bearing assembly.
It's one downside to the bearing design, but being stronger and potentially longer lasting it seems to be a reasonable trade-off for most.
I think Ford figured that, once the seal starts to leak in about 100,000 miles or so, might as well change the bearing anyway. Taking care of an issue with the old style, where the bearing might fail before the seal gives any indication of age deterioration. Not good...
Sorry for the meandering thoughts, but hey, it's a good design. Just with some pitfalls that need to be discussed now and then.
Tjboriack
Tjboriack
@74LUBR
College Station
Thanks for all the input. The install of the new third member and axles went well, we will see if the left side leaks or not, if it does I will most likely put a new housing under it.
Quick questions though - has anyone installed a new Yukon third member? Do they use a crush washer or an eliminator? What torque should be used for the yolk nut? My yolk nut is about two threads shy of being all the way on........
When I am ready to test drive what all should I be looking and listening for?
Thanks,
I am not aware of the brand of third member dictating which style you use. I always thought it was up to the installer whether to use shims or a crush washer.
And not sure what an eliminator is exactly. Got a handy link to some discussions?
The yoke nut is a tight beeatch. Seems like it's something in the 250lb range, but then maybe that value changes with a crush sleeve vs eliminator vs shim anyway?
Lots of 9" experts hereabouts. I'm always interested to learn the intricacies of setting them up.
Tjboriack
Tjboriack
@74LUBR
College Station
Hey Paul - the eliminator is a shim, i guess some call it a crush washer eliminator. I purchased by New 3rd member from JBG with a Yukon locker. It shipped from Yukon. I will find out tomorrow if it was shimmed or if it has a crush washer and hopefully have a better idea then.
Test drove the Bronco today for a little while and it drove well, cycled it through 4WD and back to 2H with no issues. No funny noises no bad vibrations. I thought i felt a small shudder at around 30 mph when under a load, but as soon as i release the throttle it went away, even as speed maintained.... Once I got back home I crawled underneath and everything looked good, the front of the third member was a bit warmer than I thought it probably should be, I will need to keep an eye on that. Not sure how warm they should get or not.
There weren’t any leaks after 24 hours, but after the test drive and it sat for an hour, I did see a small drip at the bottom of the third member. Most likely from the gasket, I used a lube locker so I didn’t silicone, will need to see if it heals itself or if I am going to need to pull it and add some silicone (which I am not really wanting to do). So far the axle shaft seal I was concerned about seems to be holding up.
Appreciate the help - any other feedback is appreciated.
Tom
