Frame reinforcement plate spacers
joshua
I’m doing the bc kit. And I’m at a bit of a crossroads with the spacers. They need to be ground to fit. Which is fine, but the only problem is that my frame has seen some stuff. And the walls are definitely pushed in a little on the way to the holes.
So I would have to grind them (spacers) pretty short to clear that obstacle. Leaving them to short in their final resting place.
But I was thinking about taking a die grinder to the holes of the frame. Making them big enough to slide the spacers in from one side. Then just welding that side back up around the spacers.
Thinking I would do it on the side the plate would be going back on over it anyway.
ntsqd
heratic car camper
Upper SoKA
I have done thru-bolt frame rail spacers by butting them against the inside of the frame at one end while welding them only to the opposite side. Strongly suggest that if this is how you do decide to proceed that those spacers be bolted down tight before any welding. The spacers should be a slip-fit in the side with the large holes so that in tightening the bolts you're not also distorting the frame. Since I made the spacers I deliberately made them long enough that the ends were proud of the frame face by enough that the weld bead did not need to be ground down.
joshua
joshua
you could try a long bolt/all thread with nuts on the inside of the frame and wind the nuts out till you're at the desired width.
I did think about this. But the problem isn’t where the holes are. It’s long before.
jamesroney
Fremont, CA
Well, yeah...you are asking the right questions. But you need to answer the question that you didn't ask before you get too far along.
Do you need to do a repair to the inside of your frame? Or are you hoping to just drop the new spacer "nearby." If you don't need to grind out your original spacers...then it is perfectly reasonable drill a pilot hole in the new location, and use a hole saw to make a hole big enough for the spacer. Then yes, it's OK to weld the head, and pinch it to the inner rail.
But if you do all that work, and you make a perfect frame rail with supported holes in the correct location...then WHAT exactly is that spacer plate doing?
All it can do is move the steering box away from the frame, and provide additional leverage for the steering box against the frame. If you want more strength and support...you really want a support plate on the INSIDE rail. Not the OUTSIDE.
I understand why the plate exists, and I understand how someone could end up buying one. And if your frame is cheese-holed and weak then you might want a support plate. But you are welding a 1/4 inch thick plate to a 1/8 inch thick frame, at arguably the strongest part of the frame, and leaving the weaker side. Every time I do this, I end up putting the reinforcing plate on the inside of the frame, with a threaded nut provision in the rearmost hole. Then I add the spacers to the frame from the outside if needed. The weld, grind, finish, and paint. Then bolt the steering box directly to the frame.
Hope that helps.
joshua
joshua
Hope that helps.
I don’t suppose adding a plate to both sides would be the best of both worlds.
Also I’m very slow, as if you couldn’t already tell by my attempt to explain my plan/situation. So I guess what I’m getting at is, do you happen to have any pictures of what you did?
Also the spacers that came with the (kit) will not be long enough to protrude out of the frame rail to put a bead on them if I insert them via new big holes in the side of the rail.
And I took from what you said that I could weld the “head” flush against the rail then grind it flat. Meaning that it isn’t necessary that they protrude out of the frame before welding then grinding it flush.
Which makes sense to me, as I thought those spacers were just there to prevent the frame from collapsing. Am I understanding that right?
Otherwise I’m waiting at least a week on some steel tubing.
As to my original spacers, bottom 2 were junk. I’m wishing I would not have removed the top one at this point. But I did knock it out.
And if I’m way off don’t kill I’m slow.. 😉
jamesroney
Fremont, CA
If you have adequate support on both sides, then the outer plate does nothing except make the bolts longer. But the inner plate allows you to use a full nut on the rearmost bolt...since you can notch the plate around the cross-member ear.
I'll check to see if I have any in my old photos. My last one I went with a factory Bronco box. But if I do, I'll send you a PM.
Yeah, that's true. But if your spacers are slightly "too long" then when you put it in your frame thru your hole saw hole...it will actually land about 1/2 way in the outer frame. Which is almost perfect for a nice MIG weld. Don't worry if you get a little bit if bead in the bolt hole, because you can always drill it out from the inside. Just fill it all up, and grind it flat. Then drill it with a fresh, new, round hole.
Yeah, you don't even want it protruding. Let it recess, and fill it with MIG wire.
Yup, they just keep the frame from collapsing. You should be able to torque the steering box bolts to about 105 lb-ft and see no flex. If you did it right, the difference between 80 lb-ft and 105 lb-ft is less than 1/4 turn.
Then it's a good time to fix it all right. If you have a welder and a grinder...you have everything you need.
You are all right...
joshua
joshua
Thanks again James, you’ve helped me several times and haven’t steered me wrong yet!
