Freeze/casting plugs
Johnnyb
Flagstaff
I installed new brass freeze plugs in my 95 mustang 5.0 block and they just seemed kind of wimpy. The old ones had some rust on the outside of the steel.
They went in with just a few taps and I am worried about them blowing out at temperature/pressure.
Does anybody have a part suggestion for quality plugs that won't blow out?
Thanks,
JB
Sent from my SM-N981U1 using Tapatalk
svastano
Pulaski, PA
I had the same issue and consulted my machine shop and they got me good ones. I don't recall the brand but if you have a good machine shop around talk to them. Especially if they build motors for people. They will have good ones! Might cost you a bit more from them but at lease you know the quality should be good.
A little green Loctite (bearing and shaft mount) will seal and hold the plugs in place.
The last good ones I found were stainless steel marine plugs. But it has been too long since I got them to have a source.
Johnnyb
Johnnyb
Flagstaff
Thanks for the replies, wish I thought of green loctite.
Seventee
In the sticks of MT
They're bore plugs - not freeze plugs. I usually buy Melling or Federal Mogul (Sealed Power) cup plugs. You might have gotten expansion-type bore plugs, which must be "set" after installation by flattening the center. Post pics.
I've never, ever heard anyone call them bore plugs.
Just for kicks, google "bore plugs" and "freeze plugs" and see which search provides relevant results.
Seventee
In the sticks of MT
You probably don't read much. It's what machinists call them because they plug holes that have been bored into castings. Ford calls them "core plugs", but you've probably never heard that, either.
No, I prefer to use terms that people actually understand what I'm talking about, but apparently you don't.
And you are not good at homework assignments. As I said, google 'bore plugs' and google 'freeze plugs' and see what you get for results. %)
Seventee
In the sticks of MT
And apparently you don't read at all, since your favorite brands also refer to them as freeze plugs, and it's what people who sell them call them:
https://www.melling.com/product/freeze-plugs/
https://drivcat.com/digipubZ/Sealed-Power-SP1502/Sealed_Power_SP1502.pdf
Sealed Power's catalog has 1033 references to freeze plugs, guess how many references to bore plugs?
So if the OP of this thread wants to search for something else to replace the parts he currently has, I suggest he try several of the common terms and decide which results are best for him. There is one term, however, I don't recommend he use...
