Unfortunately... Yes.
The caliper hoses always bugged me with the way they mounted though. I always thought the little shoulder should go against the caliper and act to keep the fitting from twisting when tightening down the bolt. But if I remember at least some calipers are cast in such a way that there is no way to fit the hose that way.
Is that what you found with yours? I see in the first pic that the shoulder is facing away from the caliper, so it made me wonder about that.
Otherwise, your calipers look correctly oriented and the anchors look correctly installed.
I do see that things look totally dry however, and the sliding surfaces should always be lubricated with brake grease or anti-seize. Contrary to popular belief these days, caliper grease is not intended for anti-squeal duties. It's a lubricant that is there for the sliding surfaces only. They sell the anti-squeal compounds that solidify and don't risk migrating to the friction surfaces like a moly-lube stuff could.
However, it does seem to work as an anti-squeal product for many people. I just wouldn't ever put lubricant on the back of pads myself. So wanted to at least throw out the PSA rant when I had the chance.
In your case though, even though things are so clean and new that it's hard to believe that it might be an issue, I would still pull them off, dress the sliding surfaces with a file to make sure they're smooth, level and free of rust or anything else, then lube them up with the proper stuff and put them back on.
You never know... Perhaps your calipers are sticking just enough to create an issue.
Worth a shot at this point.
