What piston size are you looking for? To get the driver's side ports, you can source any '71 or later Bronco master, as long as it's for manual brakes.
These will work fine with the smaller Ford calipers, but might be too small for the GM calipers. Other members here will have some feedback regarding piston size vs caliper size.
The Ford based ones are either 7/8" or 1" diameter (I can't remember). You really want a 1, to 1 1/8" master, but by the time you get to over 1" diameter, you also benefit greatly by going with a booster.
For manual, you can check out a mid-sixties Corvette with manual brakes. Usually about 1" if I remember, but I don't remember what side of the body the ports are on.
This is one of the reasons we sell masters with ports on both sides! You can see our #3083 which is an aluminum version of what a Corvette master looks like. But it has ports on both sides (unless we've changed sources) as it's a "universal" type brand new master.
Our #3140 is a stock replacement. Which, again, is potentially too small for your calipers with larger pistons. Giving more pedal travel than some might like.
