chuck
Some good ideas. Because the sender is very adjustable I looked into moving the beam up or down and bending the float wire to correct readings. I can get full and 1/2 or full and empty or empty and 1/2 but not all 3 with the same setting. The problem is the stock sender has resistor wire wrapped around a flat piece of plastic and a contact that wipes over that wire. The wire is wrapped much closer on one end that it is on the other. A new gauge is not cheap, My friend poncho-villa made a volt meter to replace the amp meter, if I remember right his cost was around $22 if he ordered 5000. The $22 is O.K. but the 5K is a lift time supply. Anyway it seems to me that the best fix would be to get a correct sender, if that doesn't work have a new face made for the gauge that is scaled to read correctly.
