fuel injection question
broncojon
I am doing a fuel injection converion to my 71 for bronco, The donner vehicle is a 1990 f150, My main question is can I use my old short block or do I have to use the one out of the 1990, Any suggestions would be greatly appreciated...
As far as I know, there's no reason you couldn't use your old block. That's how the engine I'm going to be using is set up. A '72 302 with late-model Mustang/Explorer stuff.
You'll have to decide which front accessory drive setup you'll go with, along with the front cover, harmonic damper and flywheel/flexplate for whichever engine you're using so there is no mixup between 28 oz and 50 oz imbalance factor, reverse flow water pumps, pulley alignment and stuff like that.
Is the '90 truck engine a MAF system? I'm thinking yes, but seems to me there were some vehicles in that time-frame that were Speed Density still. Maybe just the Crown Vic and a couple of cars perhaps?
I'm sure you'll get a 100% answer here, but I'm pretty sure you can do the swap with no issue as long as you pay attention to those details I mentioned.
Paul.
Oh, and welcome to classic broncos too, by the way!
You just get the Bronco, or have you had it for awhile?
B
broncojon
Ive had it for a while, was running eldebrock, the got crazy ripped off axles tranyy ad all old crap. Went full size axles, np435 and custom long arm set up will post pics soon.. The engine does use a map sensor so it is the SD. The only thing I noticed in my 71 block there is no threaded area for the knock sensor. Do I even need that. I was also wondering if I could get rid of the egr valve..
B
broncojon
I live in colorado and me and my bro will soon be doing alot of 4x4 trips if anyone is interested in joining us as well, if i get my project done anyways..
...if i get my project done anyways..
Now there's your sticking point right there! Hah! But you'll have good incentive living where you do. I'm sure you'll get some takers.
I know the SD systems don't like modified engines, but don't know how they react to being bereft of certain sensors. One of the experts there will have to say for sure, but I'd want to leave the knock sensor if you can.
Good luck.
paul
trailpsycho
Jon, there is a ton of info on the truck 5.0 swap in the archives here. There are people that have done it, but the downside is that the truck intakes are very, very tall--think a 2 or 3" body lift, then still needing to cut a hole in the hood...that tall. There is nothing wrong with running the SD elctronics of the truck, although in the truck application, I believe that is a bank fire vs SEFI. Check out www.fordfuelinjection.com. There is alot of good tech info there. What you would be better off doing is finding the EFI setup off of a Towncar, lincoln or any other 5.0 and running the SD setup off of that vehicle...lots of info on that here and on FFI. Most of us, as you probably already know, run the Mustang electronics (MAF). Dont feel that that is a requirement, any 5.0 intake setup will run fine on your motor, even without a cam swap...but unless you want to do a crazy custom hood (lacking most of the center or with a 5-6" rise) you dont want to run the truck or van intakes.
IF you cant find a set of car 5.0 intakes, PM me, I have an extra set on my shelf...but you can probalby get a set cheaper at your local u-pull-it than from me shipping them. Good luck.
Old block should be fine. For the knock sensor (actually surprised it has one) just needs to match the threads and screw into the block or water jacket somewhere. Knock echos fairly well through block and water.
Should be a speed density system. Intake way too tall to use. Swap a car intake. They are cheap. If you can take the intake off the donor and check to see if there is a spider and roller lifters. If so roller cam, wrong distributer gear for the old flat tappet camshaft. No spider, flat tappet cam, interchange with old block.
efossett
Bakersfield
Sorry to hijack the thread real quick, but I had a (hopefully) yes or no question about fuel injection and didnt want to start a new thread for it....
I have the main tank set up for fuel injection....the aux tank has an external pump and I have to manually put the fuel line into the main tank filler tube....so the question....can I put a connector into the return line so I can just pump the aux tank into the return line?
Thanks, and sorry again about the hijack....
B
broncojon
So I am picking up a mustang 5.0 intake manifold upper and lower for 40 bucks, I was wondering can I use the sd off the truck with those intake manifolds...
Well, so much for the yes-or-no part, but I'm leaning towards... maybe.
If it's a low pressure transfer pump, I don't see anything initially that would say you couldn't just plumb it into the return line. Even with the engine running, any fuel added to the line would feed back to the main tank eventually.
Probably slow your transfer down, having to share the limited space with any fuel that's bypassing the intake injectors, but it should still work.
That's my theory anyway. Haven't done it like that myself. Maybe someone can give you a better answer.
In fact, I think that's a great question for a new thread. Not that I'm against mild hijacking along the same lines, but this could open up a whole new discussion.
Might think about it anyway.
B
broncojon
Here are some pics of were I am at with it...
Sorry phot bucket cant make smaller..
trailpsycho
I am sure that you can...but why not grab the fuel rails, Thrott. body and other stuff off the Mustang or the car.
Its the whole bank-fire vs true SEFI that I would be worried about. Speed Density doesnt bother me as much as does the truck electronics (in the above respect). The car 5.0 speed density harness, computer and other support pieces are very inexpensive...and can later be converted/upgraded to MAF if you decide you want to later. I know you want to work with what you have, but there is alot more support (here, there and other 5.0 places) for the 5.0 car stuff vs the truck stuff.
HAve fun with it, Jon.
Best
John
B
broncojon
I will see what I can do, the guy has just the intake manifolds, that is why I am only getting those. They are off a cron vic..1988
