Another fuel injection question.
fordtrucksrule
So i am converting my 351w over to the all ford fuel injection setup using a gt40 lower and upper. I have shorty headers right now. when i do convert over i know i need a bung welded in my exahust do i need two or just one? also can it be at my crossover where both pipes come into one? or does it have to be at the header?
Viperwolf1
electron whisperer
You need one on each side just after the collector.
You didn't say what computer and harness you will be running (there are different factory style EFI setups), but with a GT40 style intake I would guess it is a mustang based EFI. Also it is the most popular. That style EFI uses two O2 sensors. For loaction you want them as close to the engine as possible but still sampling all the cylinders. So at the collector is the best spot. While you are trying to determine the location there are a few other things to consider. The sensor should point down, if not down at least sideways, but not up. Reason is condensation. Shut off the engine the exhaust is water vapor and CO2. As the exhaust cools down the water condenses and if the O2 is in the bottom it can collect on the sensor. That can be bad for it.
If you want to get the exhaust prepped before you start the EFI conversion you can do that too. Get the bungs welded in place and fill the holes with either the O2 sensors or a pair of spark plugs. The O2 sensors use the same 18mm thread pitch as large base spark plugs.
