So... finished replacing clutch, rebuilt TC while I was at it, then coolant leak issue so replaced heads, gaskets etc... etc.. etc...
First trip around the block, going through the gears (all 3 of them), get on it and loud pop (either backfire through carb or exhaust, not sure) and the truck dies on me. Cannot get it to start back up, acts like it wants to, just will not catch. Get towed back home. FIRST TIME!!!
Back in the garage,
Manually turn crankshaft, turns fine, so motor not siezed.
Pop valve covers off everything still looks good there and operates fine.
Pull and check dizzy, gear is fine. points etc appear okay.
Check MSD box (via their troublshoot method), appears in good order
Check spark at 1 plug, and that seems fine.
Try firing it back up and voila, it starts fine.....
Hmmm...
Check fuel pressure gauge, at '0', barely have a trickle of fuel in clear filter by tank. Carter P4070 fuel pump sounds like it is still working fine.
Replace all the fuel line with new 3/8" rubber fuel line.
From rear tank to fuel filter to Elec Fuel pump to carb, bypassing selector lever etc... for ease of diagnosing.
Still can't seem to get the fuel gauge to registor over 2psi at idle, then when I throttle it up, it drops to 0psi, but still idles.
At this rate, guessing I have a fuel pressure problem. Have never heard of the Carter pumps going south, but my plans at this point are to;
1) replace carter pump with new spare unit
2) Blow some lightly compressed are into the fuel tank sending unit (in case it is clogged) to clear that.
3) if 1 and 2 don't suffice, install a Fuel Pressure Regulator (Do these have the capacity to increase low pressure, or just regulate high pressure?)
Anything I am missing? BTW, edelbrock carb. Never had any problems before, on or off road. Did the off road springs and float adjustment awhile back.
Thanks.
Back in the garage,
Hmmm...
Thanks.
