ERLYBRONCKILLER
I have been plagued with this fuel pressure problem since I bought my Bronco and would like some suggestions. I start my bronco and it has 7-8 psi at the carb. When I run it for about 10 min it startes droping to about 3 then eventually 0. I have a new edelbrock manual fuel pump. I though it may be the vent on the cap but removed cap and nothing. I rerouted all my fuel lines and wrapped them in insulation. I also put a phinalic spacer under the carb. I don't have a fan shroud though. I don't know if that is causing the engine to get to hot. My temp guage reads fine but I am not sure it is reading correct. I am going to remove the fan and put an electric fan a sensor on to see if that helps. If anyone has had this problem or thinks they know what it is please let me know.
Thanks,
Mike
Thanks,
Mike
