Fuel sending unit lock ring tool
abrogate932
St Louis MO metro
I was digging though my specialty tool drawer last week and found a tool I made and have since forgotten. When I first inherited my Bronco it was in poor condition in nearly every way. The main fuel tank was really rotten and it was one of the first things I decided to replace. I wasn't sure what kind of contaminants I would be dealing with and it had some seepage from the seams. I got a new stock replacement along with a new sending unit, o-ring and lock ring. I prepped everything out side of the truck then installed the tank. The o-ring must have shifted when I installed the lock ring and it was very apparent once I started filling the tank. I drained the tank and struggled with the lock ring with the tank installed due to the rear crossmember. I ended up removing the tank to investigate. After I installed the tank the second time, I filled it and found that something was still wrong. Rinse and repeat, but this time I had ordered new o-ring. I installed the tank and took the truck on a test drive and ended up having to get a tow back to our farm. The tank was hemorrhaging fuel at the sending unit.
I was frustrated with the situation and determined to fix the problem in place without removing the tank. I wasn't exactly sure what was happening, but I suspected that the twisting of the lock ring was causing the problem. I was using a mallet and flat head screwdriver to pop it in place, which has always worked on other cars. With the sending unit on this tank being on a vertical surface, the o-ring wasn't staying in place and the tapping of the screw driver was allowing stuff to move around. My solution was to make a tool that would engage the four tabs on the lock ring and would easily twist the ring while I was applying hand pressure to the sending unit to keep the o-ring in place. I drew the tool in CAD and cut it out on my plasma table. I made it from 1/4" plate, which is thin enough to slip behind the cross member and the ring can be installed/removed in place. I have never had an issue since and the ring is very easy to deal with now.
full
full
That’s fantastic! Glad you were able to make one yourself.
The tools do exist, but if you’ve got your own plasma cutter, and CAD set up, why not make your own :)
This a really far too common problem. Do you remember whether you had the round gasket seal or the square profile seal?
Obviously they’re round for the hole, but the profile of the material can be either round or flat sided.
I think the flat sided ones are the ones that shift less. Also using a bit of lubricant, if you didn’t already, seems to help things.
Although I could imagine it could make it worse in some situations as well.
Too bad there’s not more of a lip to act as a guide and retainer to keep the gasket in place while you’re spinning the lock ring.
abrogate932
abrogate932
St Louis MO metro
My o-ring was a square profile. I ended up using a small about of grease to hold it in place and that helped a ton.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
That's great that you were able to make one. I got one from WH recently and it makes the process much more controlled. But something has changes with the seals. I have done these sender unit seals many times, slapped one on and thought nothing about it. Lately it is a struggle. Multiple attempts before success. Or success in one try. You can never tell. I have an aux tank right now that I can't use because it leaks when I fill it up even after multiple attempts. I am in a cooling off period before I try again. I hate doing something over and over with no idea why one time it works and other times it doesn't. But the tool certainly removes that part of the equation.
abrogate932
abrogate932
St Louis MO metro
I made this 8 years ago and didn’t know they existed. Here I thought I was a fart smeller.
abrogate932
abrogate932
St Louis MO metro
Thanks for the info.
Thanks for the links. I may be wrong, but I don't see how any of these would work with the tank installed with the cross member there. These would have definitely helped with the initial install with the tank out of the Bronco though.
