There’s no master fuse in a factory harness, however there is a fusible link (which is the same thing basically) attached to the battery side of the starter relay/solenoid.
If the harness has been replaced though, you most likely have a main fuse over near the starter relay.
Is it the original harness?
Generally speaking there is only one other thing that can kill all the power to the vehicle. And that’s a battery cable. Positive or negative.
If you checked everything, and nothing works, including heater motor, turn signals, radio, flashers, horn, headlights etc., then it’s either a battery cable or that main black wire at the starter relay.
Aftermarket harnesses typically use red wire, but the factory used black.
