Full length axles
buckenbronco
Hanson
Anyone have any info on full length axles on how they ride? I'm going to running 35 inch tires with a long arm duff 3.5 in suspension and a 2 inch body. Mainly an on road bronco but when I do go off road I want it to be solid. So will the bronco be more stable on the road? And what will be the pros and cons? Thanks
KyleQ
Full width (one tons) with 5.5" lift (all suspension) and 37's - loved the looks of this combo.
B
buckenbronco
Hanson
Why do some of the full length axles look like they stick way out when others only stick out only a little bit
Yeller
Rogers County Oklahoma
Differences in wheels. Less width and or more back spacing make it narrower. There is also a difference in axle widths a full width D44 from a 70's F150 is 3" narrower than an axle from f350
B
buckenbronco
Hanson
If i Don't want the axles sticking way out what would you recommend for axles. I like the idea of more stability and the look of it just a hair wider. I'm mainly an on road driver
Most would just recommend wheel spacers of different offset wheels. I am not a fan of that most of the time. You need to be aware of a few more thing in front end geometry besides just the basics. Scrub radius is a big one. In short, draw a line through the ball joints to the ground. That should pass through the tires contact patch. Maybe not dead center, there are various factors in play. But the tire should not be too far away from it.
