Okay, I have not posted for awhile but after a long break I started on the 76 EB again. My wiring harness is in good shape but not the fuse block. I bought the small Centec fuse panel and started to identify all the wires on the old panel. Is there not an accessory wire from the ignition switch? When I switch to ACC. the same terminal is hot on the back of the fuse panel as when your in IGN. position.The Centec has a post for Bat. Ign. and Acc. The instrument panel wire looks like it goes in and back out the same fuse and not fed off the panel. What did you all do for the accessory post on your fuse panels? Sorry for the long post.
