Crawdad
- Feb 16, 2011
- 3,635
First thing i would do is, if possible, insulate the attic. Make sure it is vented appropriately too. They make blankets for noninsulated garage doors. They are lightweight but look sorta tacky. I plan to glue styrofoam sheets to my garage door and go up one or two cranks on the doors spring to compensate the addl weight. Wont look pretty but some cheap paint may help.
I did the whole car radiator and lawn hose thing. It works very very well but its a hassle sometimes and you tend to over water the grass. Glad to have a well but can burn it up as well. Plus there is two hoses going in and out of the garage while it runs. It was a fun project but junked it after my brazing joints started to leak. This was way before i joined the AF, im a better welder now!
I am rebuilding my garage and have put 6" insulation in the walls and attic. It stays cool by itself till i open the garage door. Its about a 24x20 and i plan to go the portable unit direction. Yeah it wont get down to 68 degrees on a 100 degree day but if i can get it in the hi 70s ill be happy. Portacoolers are huge and they tend to promote rust parties on everything that has an exposed finish. They killed our machines and tools in the desert, a maintenance nightmare.
Good luck and would like to hear what you decided to go with. Im subscribed!
