Bronk74
Hello ,
I ran out of gas for the last time. So I decided to fix the gas gauge issue.
Sitsuation:
I had the cluster rebuilt by classy gauges about 5 years ago. I put the dash board in about 3 years ago. I had found the old pig tail from old wiring harness so I decided to use it. Just noticed the power side is going to ground side for some odd reason. This is a stock pigtail???I will correct this.(wonder now if i blew up regulator due to wiring backwards) ####update#### Just found also the voltage regulator is not pulsing just shows a constant 10 volts DC on my dvom. Also old sending unit shows about 101.6 ohms any help appreciated
Sitsuation:
