Jesse37932
I have a 200 engine in 66. Fuel pump went bad, so I replaced it, and the tank, all new lines, filters etc. soaked the carb and put a rebuild kit in it. Cleaning, rebuilding the carb helped a ton.
Drained the oil, it smelled a bit like gas-I heard this could happen on this forum.
So I changed it, got it running and it has developed a valve tapping sound. I havent run it much, but could the gas in oil damaged something? The head on this engine was redone 3+ yrs ago, hasnt had many miles cuz its been at the body shop.
Should I try to adjust the valves (chiltons doesnt help much at all) to make the sound quit? Or look for damage? Not sure what to do next. This is a perfect example how one thing snowballs...Im sure you guys have experienced that dejavu!
I really appreciate the help.
