- Joined
- Nov 11, 2007
- Messages
- 7,840
you tree huggers and your canpurge circuit. I love it.
Hmmmm, might look up the ford fuel injected book from the 80's/90's, i remember this book going for $2-300 back in the late 2000sSo this is how I would want to hook it up?
Doesn't hurt performanceyou tree huggers and your canpurge circuit. I love it.
I sometimes mix in what other manufacturers do as well. Work on other stuff as well.
The basics are the same, implementation and naming of parts sometimes changes.
Are you sure? The only way to really test funtionality if reporting has been disabled is to wire in a light to the circuits mentioned and watch to see if it ever operates going down the road.looks like my EVAP was disabled on the ECU.
i guess my sarcasm didnt show, yeah, all good, but also, egr good for economy and power.Doesn't hurt performance
In theory gets you better economy (you get a chance to burn the gas that would normally evaporate to the atmosphere)
Reduces the stink in the garage from gas fumes, which tends to keep plastics and rubber stuff that are stored in the garage lasting longer.
All good reasons in my book.
It might not activate at idle only.hooked it up 12v to light and to green/black wire. didnt see it go on. idled it for a good 10 min and was up to temp. how often does it cycle?
