gauges reading funny
horseman
Im not sure whats going on? Im putting things back together and the gauges are reading funny.
coolent seams to be working
oil pegged
volts nothing not plus or minus
most of the electrical system is unpluged. ( Lights wiper horn )
When I did turn on the light swicht the coolent /oil needle went to zero.
Iam a true rookie when it comes the mysterys of the electrical system. That means that I have no tools. If you could recomend any ?
P.S I did a search allready but like I said above Im a moron
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
Clarification please; is it a volt meter or an ammeter that is reading 0?
Oil pressure reading indicates a short between the gauge and the sending unit.
H
horseman
I not sure its the stock gauge. If I go get a mulit meter what am I testing/
and what readings should I be getting /where do i hook the leads to?
Thanks and im sorry if you think my ? are lame but my my skills are seriously
lacking in this area.
jbeyer
new york city
you need to do a search for wiring diagrams for what evere year you have. that and a multi meter will help. first thing would be to be sure the gauges are plugged in correctly.
post a picture if you are not sure if you have stock gauges.
the gauges get pegged when they are getting 12 volts. in the stock gauges, the power goes through a little voltage regulator that cuts it to 5volts. if the temp works thats not the problem. the oil pressure gauge has a sending unit on the engine block by the oil filter. a single wire goes back from that through the harness to the gauge. of that is shorted out, you would get the gauge pegged.
horseman said:
1) coolent seams to be working
2) oil pegged
3) volts nothing not plus or minus
4) When I did turn on the light swicht the coolent /oil needle went to zero.
1) this is a good sign, most of the system is operating
2) harness or sender is shorted to ground. Remove the wire from the sender and try again. If it still pegs, it's the harness. If it is on 0 then the sender is shorted.
3) ampmeter. not an easy way for me to describe operation to a layman. Don't worry about it.
4) sounds like a grounding issue between the gauge cluster and the body
As for tools, go to harbor freight and find a digital multi meter. Under $10 (mine was on sale for $3). Not a huge chunk of change, but it will get you started. Place it on voltage DC scale and start playing with it.
