Gear swap ratio?
matt w
;DI "Think" my 73 Bronco has 3:73 Gears.
I am not sure BUT I did rotate the tire 1 revolution and the axle spun 3 & "almost" 1/2 revolutions.
I am running 33's and do not plan on going larger on my tire size.
I kind of like the way the truck rolls on the freeway and DO NOT want the gears to where the RPM's are to high, I had that problem with another truck I owned.
It is not a daily driver at this point, cause I ride a motorcycle or bicycle to work when I can, but my Bronco is my only "cage";D So I do want to keep the gearing street/highway freindly!
It is a stock 302 Automatic...At THIS POINT!
Anyhow can I get some advice on this!;D
stlo
tulsa
i would think that you have more of the 3.55 gear ratio than the 3.73...that is what they came with stock....i have ran alot of diff gears. currently im running 4.56 but have 37" tires....hell i ran the 3.55's with 35's and i liked the way it drove...true it was alil under its power band but i mostly drove it on the highway....if that is all your going to do and just drive it on the highway i wouldnt spend the money on the gears....having the auto will be a lil more slugish then having say a NP435 manny but the savings on gas for switching gears to get back in the power band is money lost....i would rock with what you got
Stock your gearing should be 3.50 as that was the base V8 ratio. 4.11 was optional with the V8. 3.73 was never a factory option. your 3½ driveshaft turns also backs the 3.50 gears.
With the C4 automatic the transmission top gear is 1:1. If you like the durrent freeway RPM there is little that you can do to the axle ratios. To keep the same freeway RPM and go lower in the axle ratio you will need an overdrive transmission.
matt w
matt w
Ok It seems you both are right..it is probably 3.50!
I DO take this thing on the trail, rocks, sand, knarly hill climbs, so don't get me wrong. I am willing to do a gear swap to get it back to its standard power band ..or at least so I can have a little lowere gearing for those hill climbs and rocks I occasionally battle with!;D
stlo
tulsa
if your willing to spend the money and dont plan on going bigger than a 33 just put some 4.11 in it...that should keep you in the 2300 to 2600 rpm range going down the highway and give plenty of grunt for the hill climbs
If you really don’t want to turn high RPM's but keep large tires your going to have to get more grunt. At 2500 rpm the 302 is making about half available torque in your case the 73 302 if stock is going to be around 120 ft lbs. With the weight of the Bronco you hit a hill and the gearing wont let you pull it. you’ll have to downshift to second and now your revving the motor you say you don’t want to do. The only way to fix this is to get more grunt the easiest and cheapest way to do that is to swap in a 351W it makes more grunt at low RPM enough to pull the Bronco up and over pulling the gearing you desire. By the time you pay someone to swap gearing or changing the transmission and swap gearing and tranny to use overdrive I think a motor swap out is in line especially if your old 302 is about to give up the ghost anyway.
I guess I should have mentioned, 4.11 gears and 33's make for a good combonation. It will do highway just fine. I drove all over the place and did a lot of highway miles with 4.11 gears and 33's and was very happy with it. Was running a different transmission (NP435) but top gear was the same ratio 1:1. It will really help offroad as well and just make it more fun to drive.
That would bring back the pep that you lost with the larger tires and still be good on the highway. It is a common ratio, easy to find. My recomendation is to do the rear first, don't use 4WD but take it on the highway and see how you like it. If you are happy, do the front to match. If not, try a different ratio in the rear. The rear is the easiest and cheapest to change. Yes, it will cost money to try it, but nothing extra if you like it. But not nearly as much as doing both axles and realizing you don't like the result.
broncnaz
Swapping from 3.50 gears to 4.11 gears will only cuase the engine to turn 300 more RPM than it did with the 3.50's 302's dont mind reving they will run all day long at 3000 rpm. Might even consider running 3.93 gears but it will really be about the same as the 4.11's.
Personally the 33in tires and 3.50 gears is not a bad combo yes you may lose a little lowend but you could swap out the cam and get one that has better lowend and see a nice improvement in power without swapping axle gearing.
trailpsycho
If you think you might one day make the jump to an OD, go with 4.56s. If you dont think you will do that, go with 4.11s.
Alternatively, if you just want more gear for when you wheel....you might consider looking into a set of the Terra Low gear sets....that would get you the low gearing you need when you want to climb and still keep you in a false overdrive for the hi-way. You might be able to score a set of TL gears used for a decent price.
blubberfet
I have mixed gears right now, stock front and new ratio in the rear. I drove around in 2wd to see how I like the new ratio. I like it and I dropped my bronco off at the shop a few hours ago so they can do the front tomorrow.
matt w
matt w
So what size tires engine and gears are you using?
blubberfet
35's with a 351w C4 and 4.56 gears. But I wouldn't want to go this low if I did much highway driving. I did not mind the 3.50's with the 33's I had last year. It worked but i think 4.11 would have been nice with the 33's.
If you like the way it is on the highway I wouldn't go any lower than 4.11's
matt w
matt w
So from what I have read so far it seems like those with 33's, Auto-trans, Stock 302 are/have run 4.11's.
It seems like that is the directions I should go!
Are 4.11's pretty much a "safe-bet" for me?
Thanks for the input as you guys a so helpful!;D
Matt W.
stlo
tulsa
the 302 has plenty of muscle but then again im not a fan of 351's either...just remember things you see out on the trail...there is always a guy out there with stock stuff bigger tires than he should have and so on and so on....the fact of the matter is that guy's stuff works and he has plenty of fun....we have all saw that guy....lol....so its not a question of will 411's work or a 351 or a cam or any of it...it will all work...but you need to set down and decide what your plans are in the future for you bronc so you dont waste money where youo shouldnt!!!!!!!....im sure like most of us you dont have endless pockets so spend your money wisely!
cgbexec
Naples, FL
4.11 is a good gear with 33" tires and a 1/1 final gear ratio.
I'm running 35" tires with 4:56 gears. I do have overdrive however, so I can get the RPMs way down at highway speeds and yet I have good ratios offroad.
Go with 4.11s with your set up!
matt w
matt w
What cam would you suggest?;D Anything from Summit!?
broncnaz
I like crane cams there 266H is a good cam. Its pretty similar to the edlebrock performers that a lot of people run. Still if your doing a lot off offroading 4.11 gears would probably still be a good choice much less stress on the tranny.
matt w
matt w
Ya know what I am thinking of doing is a TRANSFER case gear reduction swap! That way I get that low end/tourqe on the trail and still have the highway cruiseing ability...that is why I ask about the cam!
Is 266H the kind of cam/numbers? or is it a style!;D
...I knoe not a thing about choosing and swapping cams for my engine & what that would involve!%)
Lokking for advice on this idea/concept;D
