Good electrical cutoff switch?
bsquared
Looking for suggestions for a good under the hood total cutoff switch.
I've got a very slight electrical drain on the battery and am not sure where the draw is coming from. Seems to have happened after I installed an electric compressor for OBA, but still can't get it isolated.
Battery will drain down in 7 to 10 days if she's not run. I have a mega-fuse located on the pass fender that might be a good spot to put in a cutoff switch.
Any suggestions on type / brand would be appreciated. Not sure how much the Bronco draws while running.
Many thanks, B2
bsquared
bsquared
Man, that is great scoop guys! I appreciate the info.
Many thanks and Merry Christmas! B2
BCH BRCO
Cut off switch
X2 on the Walmart switch. I have them on both of my EB's.
JohnJohn
Richmond
I've seen some looking at pics of builds on nixtrix website. I wish I knew the one he used.
I think Nick uses these.
Autocraft Electrical Switches - Specialty -Battery Cut-Off - 100 Amp Battery Isolator
nrramse
x3 - I've been using this on a John Deere Model A tractor for many years. Be sure to use the little red and green felt washers to prevent corrosion.
