The borg warner style front driveshaft for my 1970 Bronco had a grease fitting in the hole shown in the picture. It was a 90 degree fitting which appears to have been pressed in. I found no thread on the fitting or in the hole. This is my first BW style shaft, -was this a factory fitting? The hole appears to be off center slightly so I am not sure if someone actually drilled it and relieved the driveshaft to install it. Do they make replacement press-in fittings - I have never seen this before?
Doug
Doug
