Grommet for PCV on Ford Racing Valve Covers
Jeff10
Indianapolis
Hi,
I have looked for a grommet for the PCV valve on the '71 unsuccessfully for the last year. I have tried various ones from the help aisles at O'Reilly's and AutoZone with no success. I have found a few threads here about the topic; but, only a reference to "simple" grommets.
The problem with the present grommet is that when the motor gets hot, the seal gets sloppy and there's a little bypass around the PCV. I'd like to replace it to get a better seal.
I have attached some pics of the grommet and the opening in the Ford Racing valve cover.
Thanks for any suggestions.
Jeff
broncodriver99
Glen Allen, VA
That looks like it is set up for a oil cap instead of a grommet. Are both valve covers the same? You could use a stock Bronco oil cap which is designed to accept the PCV valve.
Jeff10
Jeff10
Indianapolis
Hey broncodriver,
I'll look at the other side tomorrow. I do know the other side has an oil fill... that's the one I use for filling the Bronco with oil.
Thanks for the tip on the cap, too.
Take Care,
Jeff
Jeff10
Jeff10
Indianapolis
Hi Steve,
Summit racing sells the motor sport replacements. I also had no luck with the local replacements.
Thanks to you, I think I found the correct replacement. I need to check the measurements; but, it looks like the correct application.
Take Care,
Jefff
