GT40 build for Early Bronco
Rockstar Bronco
I have a '72 Bronco (uncut) with an '88 5.0 block (rebuilt w forged pistons, fresh GT40P heads/intake, 70mm Mass Air Meter, BBK cold air intake, 70mm throttle body, long tube headers, and A9M computer). I have no idea what cam is in it and do not look forward to removing the serpentine setup to find out... though this is inevitable. Power transfers through an NV3550 5-speed (.78 OD) to a Ford BB 9" w 4.10 gears and 31" all-terrains. Total vehicle weight is <2500 lbs. (topless).
My goal is to make a torquey 300HP street driver that averages 20 mpg. Importantly, I'm at 5000' and drive from 0-12,000'.
1.) What cam would work best? I'm leaning towards E303. Is this a good choice for a daily driver that will likely never go North of 6000 rpm? I want it to hit hard right off idle and pull through midrange to WOT (doesn't everybody?). I'm aware that I need to beef up the valve springs in any event.
2.) I've read several threads in the Mustang forums discussing shorty headers for the P heads. Question: for my power goals and target rpm range, should I go shorties or long tube? If the latter, does anyone know of LT headers that will work with the P heads (in an Early Bronco)?
3.) A local guy can reflash the A9M to Cobra mapping. Assuming I would need 24# injectors and the right cam. Would this be overshooting my mark? Thinking I may be better off leaving the A9M alone and staying with the 19# injectors with the aforementioned intake components. Given my HP and MPG goals, what's the best way to go?
Any help/comments are greatly appreciated!
Not gonna happen. Period.
Ok, so that was the RDCV (Readers Digest Condensed Version) so I could get it out of my system. More details in a few minutes.
Oh and welcome! ;D
Hey Rockstar, welcome to CB! Sounds like a nice engine so far. Maybe it's got a good cam in it already (one could hope anyway)
And for the record, it ain't gonna happen. At least not all of it, and the way you want it.
You can find the cam specs without removing it. In fact, it might even have a part number on the snout, but without removing all the front drive stuff, you could pull a rocker cover and put a dial indicator on a pushrod to see what it's doing. That would at least get you close, but with a cam degree-wheel too, you could map out the entire cam and see what you have for sure.
First, your Bronco weighs in at 4000 lbs easy. More if it's got bumpers, big tanks, bigger tires and lift and such. Mine weighs 4250 with gas and tools.
Good gear ratio for the 31" tires. Go too much taller on the tires though, and you'll start losing your overdrive ability unless the motor you build is a super low rpm torquer.
Like I said, it's not going to happen with a Bronco. Especially at higher altitudes. Period. Not unless you have some magic potion to make the motor do it all. Which so far has been fairly rare.
The 300 hp out of a 5.0 is easy. Torque is easy too. But at the same time? Nope. And 20 mpg at the same time too? Nope again.
High altitude too? Makes it just that much harder.
As many (including a couple of my close friends) have found, the E303 is a super-crappy cam for a Bronco. Especially if you want efficiency. Yes, it can rev. And yes it can build close to that 300 hp you want if you do it right, but it can't do it all and it's a lousy low-rpm cam that will pull, but not as good as other cams. Mid to WOT is good, but idle and off-idle is mediocre in my opinion.
None that I've seen. They all "fit" the "P" heads of course, but that plug is a bear. And that's shorties. No longies that I know of, but call Melissa at Bronco Hut to see if their larger diameter headers would work for you. Ours (Wild Horses) are the traditional low-rpm torquey 1 1/2 diameter tubes, where BC's are the slightly larger 1 5.8" tubes for a little higher flow, especially at higher rpm, and Melissa's (Bronco Hut) got some that are even larger (1 3/4" I think?) as a special order item. They're semi-block hugger types that supposedly fit the P-heads.
I'm going with long tubes myself, and with your goals I think long tubes are better. But you may not have a choice with something for the P heads. Especially in an Early Bronco chassis.
3.) A local guy can re-flash the A9M to Cobra mapping. Assuming I would need 24# injectors and the right cam. Would this be overshooting my mark? Thinking I may be better off leaving the A9M alone and staying with the 19# injectors with the aforementioned intake components. Given my HP and MPG goals, what's the best way to go?
I think the re-mapping and larger injectors are the proper way with the setup you describe. It's still contra-indicating the mileage and performance goals, but the max HP goal along with some reasonable drivability on the street and trail in an EB is much easier with the tuned and tweaked version I would think.
Here though, I'm a fan of the 19lb and more stock-ish cam school of thought. But to reach the level of performance you want up to 6000 rpm and some right-foot-fun (which is what it sounds like your primary goal is) I think tuned, tweaked and larger is better.
Good luck with it. I really don't mean to sound like a negative-Nellie, but I'm pretty sure your goals are completely out of line with some of the components and the given application. It's all achievable. Just not all at the same time.
Got pics of your rig?
anoblefox
The E cam is NOT a good choice for a truck or bronco, period. In my honest opinion the C&L type mass air meter housings do not work well for street driven vehicles. I have considerable experience with both of these items and this is MY opinion, for whatever you think it is worth.
rguest3
welcome to CB.
I will put my vote in too.
You will be happier with the Current cam compared to an E-Cam. (I have an E-cam on my shelf I will sell you if you want) There is a reason it is on my shelf. If you do decide to change cam I would suggest a Comp Cam XE264HR, it has a 114' Lobe Separation and is Very EFI friendly. This cam would match very well with what you already have, has good torque and broader RPM range.
I agree about the C&L Meter too. Tried them before and they are junk, IMO. If you do go to larger injectors you have to have a matching Meter. Pro-M has both and are excellent quality.
4.10 Gears, 31s and NV3550 should be perfect, so you have a great start with drivetrain.
Don't see the 20MPG happening though.
Annapolis76EB
Annapolis, MD
I agree 100% on not using the E-Cam. I have a very similiar motor to yours right now with a C-4. My 2 biggest regrets from this motor build were running a mustang cam and not getting a higher stall TC (I am running a very low stall remanned C-4 for who knows what vehicle). I am getting ready to do a 347 build and am going to use the XE256H cam (flat tappet). I wanted very good street manners, a good idle and a power band from idle to 5k. The 264HR is a good cam, but the powerband will be higher in the RPM range than you might like. If it were me personally (wanting to melt the tire on the low end but no need to go ver 5500k), I would look for a cam with 110 lobe seperation, 480-490 lift and 220 or less @50. Lots of guys know more than me, but from my last few years of experience trying to do the same thing you are doing, I have found you are going to lose torque (which I want more than HP for the seat of the pants test) the more lift you add and wider lobe seperation you get. Unless you are running 5500 and higher RPMs, I would stay away from the Mustang cams you are going to hear a lot about on Corral and the other racing forums. Trust me, I learned the hard way.
WheelHorse
Did the '88 block come from a GT?
Stock Mustang cams were actually really good cams in regards to making low-end torque.
19# injectors are good to 300 hp naturally aspirated.
The biggest bottle neck on Fords are the exhaust ports. 30-40 hp could be had just be extrude honing those irons and adding the long-tubes you desire. I think you'd be happy with it, but it will never pull like a 351.
20 mpg I'm unsure if any EB owner has actually reached this not using a diesel 4b conversion.
Annapolis76EB
Annapolis, MD
I would caution against the stock Mustang cam. I am running it right now in a 5.0 roller and it does not have the low end torque many believe it to have. That said, I do know others that have degreed that cam and had good results, but just slapping it in as is not going to give you the torque you are looking for. I am only speaking from my own experience with an almost identical motor (different trans).
Mountain Ram
Recovering Masshole
Abingdon, VA
I have over a year on my 347 now... I run a C&L with no issues whatsoever. 30lb injectors, 76mm TB, 76mm C&L Maf, modified explorer intake on a stock ford A9L. It is not optimized, but drives great and has no issues. Hopefully this summer I will put it on a dyno and have the computer tuned.
Stay away from letter cams or Mustang targeted cams in general. I have an XE266HR recommended by Comp and love it. Nice lopey touch to the sound, but plenty of power thru 5500rpm. I am running Edelbrock heads and Hedman full length headers. Compression is a touch over 10:1 and I have to run 95 Octane.
It pushes my shoebox on 7" lift, 4.56 gears and 37s... gets terrible mileage, but that is not why I drive this rig!!
Ourobos
Big Island Hawaii
19# injectors can support 300 N/A horsepower no problem, I've done it several times, I'd go with those, less drivability issues.
I went with a HO Mustang cam, I advanced mine 4 degrees to bring the powerband down in the usable range.
Rustytruck
I'd be changing the cam too and advancing it 4 degrees. Get your truck down in weight and for the 31 inch tires they would be skinny and not wide. I would lower the truck and cut the wheel well bigger for the tires rather than lifting it. 19 lb injectors should be Ok since your not reving it. I dont think the 4:10 gears with the overdrive is enough but advancing the cam will help. Effeciency is in the 3000 rpm range so you need to keep it there as much as possible. Your big issue is your altitude and the only way to help with that is weight, rolling resistance and wind resistance. I think you can get to 20 mpg but not in a Bronco anyone wants to drive. If you driving from 0-12,000 feet your not driving freeway so you need quick responce to get the truck in most efficient mode as soon as possible. Gear to your 4th gear not to your fifth since you will never be in 5th.
EFI Guy
TheEFIguy@gmail
BFE
I agree with pretty much everything mentioned so far. Except for the 110 lobe separation. You want an LSA of 114. The Comp 35-349-8 is an excellent choice.
I'm also not a fan of the C&L meters and prefer to switch to a slot type MAF.
19's or 24's would work ok for injectors, but get the thin body (Explorer or Navigator) type if you can.
Then all you need for 300hp is a little boost. All you'll need for 20mpg is a Cummins and a towrope.
