H4 headlight install question
Shredin38
Newbie question for sure.... Where does the adapter plug in to power the new headlights? Everything is taped pretty heavy inside the engine compartment and the POs have done a number on the wiring under the dash, so a starting point would be a huge help.
Thanks in advance.
Not sure what you mean by adapter Shredin. All H4's use the same 3-prong headlight plug as the stock ones. So it's just a plug-n-play and bolt-n-go unless there is a physical size issue like on some brands.
Or are you referring to adding one of the headlight relay harness kits? If that's the case all of your wiring is under the hood and you use one of the old headlight sockets to plug into.
Otherwise, not sure what adapter you'd need.
Got pics?
BroncoDawg
Bishop, CA
The headlight power coming from the switch becomes the switch leg to trigger the relays and you source the main power to the H4 relays from your solenoid or battery. Not sure about "adaptor" Had to read the instructions a few times myself (shame, shame, I know), but pretty straight forward.
