Headlight install issue/question
jasonbcoutant
I am replacing the OEM headlights with LED and am using the OEM tub. I am having trouble getting them bolted in. Are the only three things holding the headlight in the two adjuster screws and the spring? If I adjust the adjuster screws pretty far in, the headlight still wiggles in the mounting hole and you can even wiggle it out altogether. What am I doing wrong? Am I missing some other screw or bolt that actually holds the thing in there?
BGBronco
N A S H V I L L E
Tennessee
I'm assuming you mean bucket not tub. There should be no issue with adding the LEDs with the existing buckets and hardware. Without seeing where you are in the process, the bucket, adjuster screws, and spring did not need to come out.
The process for replacing a headlight is: Remove Chrome Trim, Remove Retaining Ring, Remove / Replace Headlight. There is a notch on the forward facing adjuster screws that it sounds like you are not getting the retaining ring into. You can see it on the picture here if you look carefully on this link.
https://tomsoffroad.com/parts/66-77...2-HyDOSrpu-xs-7J5-OAaFDnc_ex9aqMaAsisEALw_wcB
nvrstuk
PNW
... I remember having issues with the sealed beam correctly installed (I've done a few of these) as my headlts would still "move" when I wiggled them- not much but.
So I put a little pc of rubber inner tube where the notch was. Bingo- easy, couldn't see it and no wiggle for a decade on that last fix. With my new led's they didn't need the pc of rubber and I could notice a slightly different shape on the headlight contact area than the led contact area.
Anyway, the thin pc of rubber idea works great if you need to use that idea.
m_m70
Prescott AZ
No, the adjuster screws and spring do not hold the lights in place
Sounds like you're missing the retainer ring if you can wiggle the light out of the bucket.
J
jasonbcoutant
This helped me a lot. Thank you. I had completely removed the bucket, which was completely unnecessary. Man, that spring on mine must be from 1971. That thing had almost no give.
The springs can be real buggers! Sorry you had to go through that.
Did you get it sorted?
Speedrdr
Legend in my own mind
Paris, MS
Paul, the 2 things that caused me the most frustration, skinned hands and “sailor type” language on my previous EB were 1) headlights and 2) replacement of heater cores. The jury is still out on the current ‘77. Lol
Randy
