hard start when warm
Master Chief
Aftermarket intake & carb? Edelbrock by chance? If so, you are most likely boiling the fuel out of the carb after shutdown. This is a known issue so they sell a heat insulator gasket (p/n 9265 or 9266) to prevent the problem. I had to do this to mine prior to my restoration.
HEAT INSULATOR GASKETS
Designed to help prevent fuel percolation in Performer Series and Thunder Series AVS carburetors exposed to extreme underhood temperatures.
Page 35 of this document: https://edelbrock-instructions-v1.s3.amazonaws.com/edelbrock/carb-tuning-guide.pdf
And when you say hard to start, do you mean that the starter cranks more slowly when warm? Or it takes a lot more cranking before it fires up, but the starter spins as fast as normal?
B
bobtail
high in the desert
yes I gave it a cam along with an edelbrock performer intake. and a holley street warior carb. yes I mean that it takes more cranking at the normal cranking rate. It would be nice if this were related or the answer to my sluggish clutch problem. wishfull thinking. I will get a spacer. I already had to cut a hole in my hood so there is plenty of room. thanks
B RON CO
Statesville, NC
Hi, are you holding the gas pedal down when you crank it when warm? The throttle should be open. Good luck
ared77
I've had old Ford engines with carbs (most were Mustangs) since I was 16 years old. And most, when tuned properly, will start with the flick of the switch even if I'm out side reaching in. So I'm not sure about the open throttle idea. Fully agree with fuel boiling out as a possibility or maybe a timing issue?
blubuckaroo
Grease Monkey
Ridgefield WA
The Edelbrock carb seems to be more affected by this "carb percolation" than some other carbs. This problem seems to be worse with modern fuel too.
Ford even recommended that you partially open the throttle when starting a warmed up engine.
Don't pump it then. Try just holding the throttle open.
The pumping when cold is a given in most cases with carburetors. Not only does it set the choke but it pumps some raw gas right into the intake so extra fuel is ready to make a nice rich mixture and easier cold firing.
But if the issue is too much fuel in the intake when having trouble hot starting, then pumping is just making it worse. So at least try the hold-it-open method a couple of different times and at different throttle settings to see if it at least makes a difference.
