Hate to ask, help ID a block 302/351
73azbronco
Hello, I have a block out of a 70 EB, 302 heads, no intake nor timing chain cover or water pump, i think it is a 302. However, the casting info says it should be a 351W. casting info says C9OE-6105-C which should be off a 69-70 Torino. The oil pan to deck height is right on 5 inches. Intake galley deck to deck is 5 3/4 inches, these measurements lead me to think 302. Here are some pics, this is casting info:
beemerhog
side of block, some say the triangles above the freeze plugs mean it's a 351, but i think those need to be diamond shaped and between the plugs.
beemerhog
Here is photo of front by distributor
beemerhog
so what do I have, a 351 or a 302? thanks
BUCKETOBOLTS
Salisbury, NC
You should have a 351W.
Measure across the block at the intake just behind the dizzy. A 302 will be 7 1/2". The 351W is wider.
73azbronco
73azbronco
I should have a 351, but Thats what I'm saying, it measures 5 3/4 inches, not 7.5. So the casting number is wrong? Deck has been milled down alot? Ever hear of that?
bax
Old Member
1970 351 w motor. build date is before 10/70 a 2 barrel motor.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
It's a 302. The Distributor picture gives it away. The Head bolts will be 7/16", and the distance between the intake bolt holes should be about 8.5" on the 302 vs 11" for the 351W.
I don't know how these other guys missed that.
73azbronco
73azbronco
Thanks, it has to be a 302, 7/16 head bolt, measures 7 3/4 intake bolt to intake bolt across the intake, but whats up with the casting ID number?
Casting number or not, that distributor picture is a 302 block. No question about it. I even went out and looked at the 302 I have on the stand and the 351 under the hood. No question, 302 block.
bax
Old Member
Ok OK, it's a 302 with an F'ed up casting # So its a 69 302 out of a torino.
That must make it super rare and collectable;D ;D ;D ;D
Just need to find the one sucker who think that way and has money%) %)
I can't believe For would ever let a mistake leave the factory:-X :-X
broncnaz
Nothing in the casting code will tell you exactly what engine you have. 6010 is the basic code for all engine blocks be it 302 or 460.
C9 OE -6010 -C
year vehicle basic part revision
73azbronco
73azbronco
Thanks folks, it's a 302, now that it's apart. Why the messed up cast number, who knows, who cares. Aagain, thanks for the help.
