Hate to ask
12gabronc
Canada,B.C.
I want a good weekend driver, probably never going to leave the pavement but I still want something exciting to drive, not that concerned about milage but I dount want to look under the hood to tweek this and that! I'm starting from scratch, my 74 had a 302 and I am thinking I will just keep my C4 trany.I have a $6000.00 budget,and I am leening towards a stroked 351W,suggestions?
bronconut73
Stroked Windsor is a lofty goal but you have the budget.
That low end torque of a stroked Windsor will put a smile on your face everytime you accelerate!
swampu
Biloxi
I don't have a stroked windsor but my freshly rebuilt windsor will pin your head back and bark my 38 boggers! Good plan take some vid. and post it up.
broncnaz
I tend to agree with the more or less stock 351. My carbed engines run very good hardly ever need to tweak anything but it does happen from time to time. I get the impression your leaning towards EFI?
If so you need to factor that into your budget and a stroker will need some tuning to make the EFI run as good as it should.
Basically I'd build a mild 351W and ensure your axle gearing is correct for your tire size and driving needs.
Stroker if there is some budget left.
351 based is a must. Good flowing heads but still a mildish cam. You can get a good breathing engine that is fun and still have good manors. Next is build it with some compression. 10:1 is a good target. With a mildish cam you can build some good cylinder pressures that will make some strong torque. Run on the high side of the recomended compression ratio, the aluminum heads will help with that.
Don't worry about the myth that compression doesn't make that much more HP. It isn't the HP you are after, it is the torque that makes for a fun driving engine. And compression does wonders for making torque and fun. Just need to keep it low enough that you can find gas for it. Weekend driver, just plan for premium gas and enjoy it.
If after adding up all the little nickle and dime stuff that kills budgets you find you have enough left, go stroker. don't forget to balance the options, a stroker kit will mean you don't need to pay for machine work on a stock crank. That helps offset the cost of the stroker kit.
Aftermarket aluminum heads means you don't have to invest money into stock iron castings. That helps offset the cost. By the time you rebuild stock iron heads, new parts, real port work (balanced evenly between all the ports, not a shade tree port job) the aluminium heads will be a better deal plus you get the benifits of aluminium that you can't get with iron. Get something nice like trickflows, AFR, etc. The no name import heads do not have a great reputation except being the cheapest thing out there.
bad 68
Northest Washington
Things that make my Dialy Driver Bronco fun to drive in the order that I find most important:
5spd trans with a healty 351W and correct axle gearing!!
Power stearing and Ford power disc brakes.
Awsome soud system. This could be moved to the top of the list when I need woke up on the way to work.
Delayed wiper switch. This too could be moved to the top of the list on a mild rainy day!
