74lumenaire
Can I clear 37 X 12.50-17’s with 3.5 inch lift and a 2 inch body? Anyone have pics?
I will have the fenders cut! Also will. 5.0l and a 4r70w and 4:56 gears be ok for a set of 37’s
.......You need 4.88-5.13 gears. I would hesitate to go deeper than 5.13s, as the pinion is getting awfully small and reliability will start to suffer.
(smaller pinion = high tooth load = greater breakdown of oil and tooth wear)
Aso will 5.0l and a 4r70w and 4:56 gears be ok for a set of 37’s
^^^ This is the reason we have found that 37’s are about the max tire dia. the Dana 44 can handle.
Mark
Funny, that's a new one on me and I've been messing with and driving 4x4 vehicles since the mid 70's and have never heard of this. I've had a couple of mid to late 70's F150 4x4's most just had 4:10 gearing,but had 4 speed transmissions. One had the 351M engine and the other had the 300 I-6. While I never did any actual recreational 4 wheeling those trucks got some serious workouts getting in and out of some of the areas that we used to hunt at Ft. Knox back then. Some of the roads and trails we drove getting into these areas were in real bad shape from military use and if your vehicle was not lifted with over-sized tires you could not get through. I ran Mudders and Ground Hawgs on those trucks, 38-40 inches tall and not even once, did I, or any of the guys I hunted with have a problem with the 44 axles in our trucks. But I guess that depends a lot on the guy behind the steering wheel knowing how to drive.
