mnido
- Jul 20, 2007
- 978
I am doing a frame off build, welded all the seams on the frame, filled excess holes, welded seams on body, (rear quarter), replaced fool pans, fit fiberglass inserts. I braced the body at the door openings. Today I test fit the body with a 1'' body lift and it fit terrible! The only way to get the body lines correct were to remove the two middle 1'' bushings and leave the front and rear in. In that figuration the lines are good, the hood is good, the inserts look great?? Obviously something gave somewhere. My garage is level and the frame rails at all for corners measure the same. I only have about a 1/2'' gap between the body mounts and the center frame mounts. Everything else seems Ok? What do you think? Has anyone experienced this or is this the luck of the Nido ?
