Head/Valve Question?
EPB72
Pleasant Hill, CA
Those rails are important to keep the rocker aligned on the valve tip. By grinding them down, they are now compromised and you risk more damage. You also risk knocking a valve retainer loose and dropping a valve into a cylinder. The pushrods are a secondary issue that will need to be resolved when the correct valve and rocker setup is in place.
I would not continue to run this engine without fixing the problems or it could get much more expensive real quick.
AGREE, park it until repaired properly..I’d also consider the rocker arms junk at this point with grinding on them . . With the time spent grinding rockers and readjusting lifter preload you could of had the heads nearly removed ..
green61bug
green61bug
Greensboro
Didn't have to grind the rails down and there is plenty of meat there to make sure it stays over the valve correctly. Took just enough off the backside of the rocker to keep it from hitting the retainer. It's not a hi horsepower motor nor do I drive the crap out of it everywhere I go. I dont believe I have anything to worry about moving it around or driving it honestly but I know it isnt right and will get it fixed correctly. I also know that the rockers are trash now and will install a new set when I get the proper valves installed. At least thats the plan. If it blows up I'll drop it off with SurferB and let him put an explorer motor in it. Haha
