Theirs are shorties too. I'm trying to explore long tube options before I go short.
We still have long-tube headers as well. Shorties are just the answer to more of the questions getting asked in this modern era.
And probably your answer too. I can't say for sure whether the long tube versions fit the 4R70 or not, but I believe there are some running them.
I'm trying to read up on the differences of going short vs long. Seems I keep seeing that long is better for low end torque, however I've also seen stuff that contradicts that. Have any of you noticed a difference?
I doubt it. Other than fit, most EB owners would be hard-pressed to feel a difference between one or the other. There likely
are differences, but you'd probably only track then on a dyno. Or on a highly trained and tuned "butt dyno" for some.
And as for the discrepancies you read, get used to it. They will almost always be there. Different people, different vehicle setups, different conditions... Different experiences.
And with the ease of disseminating information these days, you're going to hear about it no matter which way it goes.
No expert but I thought long tubes helped in the higher RPM range and shorties helped on the low end and mid range RPMs.
Sounds kind of familiar, eh?%)
I think it comes down to "tunable performance" and the ability of a long-tube header to be more finely tuned to a particular engine combination, more easily than shorties can ever be.
The only reason we have what has become known as the modern shorties these days is for for adding a little power with the ability to still easily pass smog certification. Period.
There have been short headers in the form of block huggers and custom fit ones for specialty applications, but for some reason (max performance tuning most likely) they never quite caught on with the hi-po people in the past.
Along come Mustang shorties in the eighties and voila! A new category was born!
As it turns out, shorties also ended up being easier to fit in a lot of vehicle chassis' (think EB's here!) and much easier to find their way into cross-over 2-into-1 exhaust systems.
They still are made to be better flowing than "most" factory exhaust manifolds, but their primary introduction was to match the Ford factory exhaust headers (crimped small diameter tubing) with more free flowing versions that would mate up to the factory flanges to keep the cats in their stock locations.
For me , it came down to what fit and ease of install. Shorties won hands down.
There ya go. That's probably the same answer that the majority of EB owners will come to.
There are probably some out there that can tell the difference between a short and a long header. Maybe even the difference between one brand and another of the same header. But more likely in a hi-po street car than in an often poorly geared, big tired, low-rpm living, aerodynamic turd of a clunky old utility vehicle like a Bronco.;D
