Headers for a 351w / 4R70W combo
bronx
Austin, TX
I'm about mid way through a ground up restoration and it's time to decide what to do for the exhaust. I have a 351w mated to a 4R70W transmission. I also have a 1" body lift from wildhorses and a 3.5" James Duff lift with the extended radius arms. I really like the Thorley long tube headers, but I am not sure if they will fit. Does anyone know what headers will fit with my application (Thorley, mustang shorties, equal length shorties, etc.)? I would appreciate any pictures and advice. I have searched the forums by the way.
That is my exact combo...
Hooker 6909 will NOT fit
The old set of Duff (or was it K-bar-S?) fit, but was way too close for comfort.
Currently running cast iron K-code manifolds that were port matched to the heads. Real happy with those. As for performance, it produced the highest HP and torque numbers on a recent group trip to the dyno. The bolts don't back out and fall off either.
B
bronx
Austin, TX
Thanks Broncobowsher
Broncobowsher,
I appriciate your information. I will look for some replica k-code manifolds and keep that as an option. I would really like to go for actual headers, at least for the cool factor, but if it just doesn't work then I will definately use your suggestion. Also I'm in Tucson, where are you in Arizona?
Thanks,
Bronx
Shelton823
Dont hold back
What were the Hp and Torque numbers. What engine set up u using do tell.
wildbill
Old Bronco Guy
%) %) %) Hooker wheel well will work I think the # is 9814 but not sure good luck. %) %) %) Bill :cool: %) :p
I forgot about the wheel well headers. They should work but might get complicated if you keep the side tank, want to run full length exhaust, ditch rockers or anyother reason not to run exhaust under both seats.
You can read all about the dyno day at www.azbronco.org or wait for it in Bronco Driver.
I live in the Burbs of Phoenix, East valley near Williams gateway airport.
I posted some information about the K-codes a while back. A search should find it.
B
bronx
Austin, TX
The engine
The engine is a ford motorsport engine: M-6007-J58 and makes about 240hp in its stock forum.
link: http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=5679
For the price of $2400, it seemed cheaper to buy this complete engine and add some aluminum heads and an intake manifold for about $1400. This combo is much cheaper than the M-6007-E351E create engine and should have similar hp figures. The engine is built on a 95-97 roller block and should be a good investment.
BoltBuster said:
Does anyone sell cast iron K-code manifolds replicas?
I got mine off eBay for about $200 for the pair.
Check any mustang restoration shop. Don't need to spring for NOS or exact reproductions, just need something that works. Be prepared, the exhaust hoos up at a different point, so it is not a direct swap for the old log manifolds. It also will not clear the stock mechanical clutch linkage. But with an automatic that isn't an issue.
B
bronx
Austin, TX
k-code replicas
Here's a link for the HiPo / k-code exhaust:
http://www.metropartsmarket.com/catalog/image_classicmustang_c14_2033.html
Also if anyone is interested in a 4R70W transmission, I purchased the transmission from: http://www.jonbarrett.com/
Contact #: 1-877-943-7040
They should still have a couple of new 4R70W 4wd transmissions with stock torque converter for sale, I got mine for $725. The also have some complete explorer fuel injection manifolds (throttle body, fuel rails, white injectors :'( , etc.)
B
bronx
Austin, TX
fender well headers
Does anyone have some pictures of the hooker fenderwell headers? I am interested in them if they work with the 351w. Also is there any downsides to the headers or possible installation problems? I have a single gas tank from bc broncos and the duff suspension (shock hoops, rear shock mounts, and extended radius arms).
