Are they standard port heads, or the extra large ones? What other specifications does the engine have? Such as cam and intake?
Reason I ask is that just TF heads doesn't make an engine a fire-breather that needs bigger headers. But set up with big cam and big power needs, it might.
Ours use 1 1/2" primaries, which even is good for keeping exhaust velocity up for good scavenging at lower rpm levels.
BC headers use a 1 5/8" primary tube, which would be better for a deep breathing setup.
Bronco Hut headers are available with up to 1 3/4 or even 1 7/8 inch primaries I think. Special order, but for a real fire-breather with some high rev expectations, that's the ticket.
You definitely need headers for a Bronco chassis though, or you'll have to do some customizing yourself usually. The taller 351 engine helps some, but not enough to make a Mustang header the ideal choice. They might be cheaper, but how much time do you really want to spend turning them into Bronco headers?
If your heads are the big port bad boys, you need to make sure you have the large mouth headers to fit. None of the initial ones I mentioned would be in that category, except for perhaps the BH 1 7/8 inch ones.
For continued discussion purposes, what model head and what other mods are you working with?
Is the "185 CNC" the model designation, or just one of the features of your particular model?
