Headlight Dimmer Problem
MSwheelin
Iuka, MS
I have an issue that I am guessing is pretty simple but I must be missing something. My headlights only work in one mode. When I step on the dimmer switch to go from low beam to high, they go out and do not shine at all.
I first assumed this was a dimmer switch issue so I installed a new one, but this did not fix it.
What else might it be?
Does you Bronco have stock headlights and wiring? Or do you have different headlights or updated wiring using relays to better light the headlights?
Viperwolf1
electron whisperer
Might want to check if the other beams are burnt out.
sykanr0ng
Did you check the dimmer switch connector?
They sometimes become corroded or loose.
M
MSwheelin
Iuka, MS
Still has stock headlights and switch. I'll check for loose connections but I have not seen any so far in my search.
B RON CO
Statesville, NC
Hi, I would take my test light and see what is going on with the three wires at the dimmer switch. with the headlights on, two wires should be hot, one feeding the dimmer and one out to the headlights. If that is working, check for current at the headlight bulb. You may be able to use your test light right behind the grill, directly on the headlight. Good luck
Yep, and if you find power at the headlight connector in both modes, then likely your headlights on that particular filament are burned out, like Viper mentioned.
