Heat reduction
KRAWLER
Southwest VA
Wanting to reduce my thermostat reading just a bit. Running a brand new 5.0 from 89 mustang EFI with serp off 98 explorer. Running factory 1974 fan, with Jegs aluminum radiator with no shroud. Temp gets up to about 230. What do you recommend to cool it down. Bought a clutch fan from a member on here from the explorer 5.0. Let me know your radiator/fan/shroud combos
Mountain Ram
Recovering Masshole
Abingdon, VA
That's too high Dave... Mine runs 195 all day and may get to 200 if sitting on a hot day. I am running a stock 302 Bronco radiator with a regular fan (no clutch), but I do have a pretty good shroud (done by the PO) and have the fan less than an inch from the radiator.
What thermostat are you running? Thermostat not installed backwards... Wrong rotation water pump, wrong rotation on the fan?
This surprises me with your new, mild FMS engine....
Have you also made sure that your gauge is reading correctly? Can you verify it with an independent new gauge, or perhaps one of those hand-held thermometers pointed at the sending unit area?
Might be worth a quick test before you dig into all the possibilities.
ransil
Stock fan on a serpentine set up I don't think is right, they turn opposite directions.
major
Knoxville
I have an 86 5.0 and it is a CCW rotation serp set up. I would recommend a good shroud too
ScanmanSteven
Shroud, shroud, shroud. BTW, you need a shroud. The shroud directs the flow of air through the radiator and across the engine, not just scattering it around. I have the explorer fan and like that setup. I fabed up a shroud and it helps move lots of air.
KRAWLER
KRAWLER
Southwest VA
Yep, got the fan on backwards to compensate for the rotation. I bought a shroud from Jegs that directly fits the radiator i bought. My factory ploder fan looks to be 18" and the Jegs shroud has a 16" opening. So, should i ....
1. Buy an aftermarket fan for the jegs setup or
2. Buy factory ploder radiator and shroud and mock it up?/
Mountain Ram
Recovering Masshole
Abingdon, VA
Do you need a clutch fan?? I don't think it is necessary. I would think a reverse rotation fan would be available at a local parts store... and maybe even in the 16" size to fit the shroud you have. Bigger is better though...
AZ73
Putting it on backwards doesn't change the air flow. It's still pushing the air forward instead of pulling it backwards. They operate the same way front or back. That's why they sell REVERSE flow blades. The BLADES are opposite. LOOK at it spinning. The part of the blade closest to the radiator should be leading the turn. I can guarantee you that if you simply flipped your fan over, it's trailing.
jw0747
San Antonio, TX
I run a plastic shroud and have no issues... and my truck runs right at 195... Whats wrong with plastic?
has zero to do with temp. enough twist and it'll either break or pop loose. that is if it reaches you in shipping and isn't broken.
bronconut73
X2 on this. Shroud. Appropriate fan.
If you "only" run 230 with a fan running backwards I'd say your cooling system will be fine when you get the fan and shroud straightened out.
WARDOG
Graniteville, CA
PLUS another on Shroud. Make it aluminum. I had a plastic, fiber/plastic stock shroud that absolutely grenaded due to an indecisive squirrel crossing the road, sending minced squirrel and plastic shards into the radiator.
A feral cat did the same thing when I went out to start my '77 F150 in the snow. Apparently it was nice and toasty on top of the water heater. Had to finish it off with an axe. :eek:
KRAWLER
KRAWLER
Southwest VA
Alright, here we go.
Got my explorer fan put on, the stock ploder fan is 18" diameter. My aluminum radiator has a face (fin surface) area of 17"x18". There is no possible way to build a shroud on it. We tried everything, eventually drew it up on CAD, no dice. So i am thinking, who has done this before.
Ordering a 98 ploder radiator and shroud to match the serp, Who runs this setup? Does it work?
