heat reduction
HotWheels
Twilight Zone
My setup: 77 351w, headers, Ron Davis Radiator, Tom's fan shroud, Flow Kooler pump.
I have a tranny cooler on my inner fender. I was thinking of making holes to suck the cooler are in from below. I am planning on fabbing an aluminum plate for below the inner fender well as a splash guard not that it is actually needed...but I figured I'd try it.
My gauge read 210 on the hi-way 2 hour ride @ 80. I believe the gauge is off as I lasered the radiator. I even tried the meat thermometer in the radiator method. Gauge seems to be off.
I am still going to put some water wetter in her. Good stuff from what I understand and have read.
wrapping headers/exhaust only promoted rust....unless you use por15 under it....hmmmmm....
broncow72
Village Idiot
Spring,TX.
walker949 said:
Heres some pictures of my 20 dollar cure.
Underhood tempuratures are now controlled
TOFIC
Very cool idea. (no punn intended ;D ). I had trouble cooling mine on the highway until I traded the Torino style hood scoop for the fiberglass bubble and then drilled holes on the side. Scoops pressurize the engine compartment and was told by the old school guys at K-S that holes on the back of the bubble also can create pressure in the E/C. They told me they did an airflow test with streamers taped all over the front end doing 80 + mph on the highway and found the airflow did not go over the windshield smoothly but had great turbulance where the windshield met the hood.
Nobody mentioned a scoop or bubble, so I just thought I would share this little tidbit of info I had acquired. Hope it's useful to someone.
BroncoJAK
Where did you get your tranny cooler? Looks real similar to the one I'm Going to use for my PS cooler. Mine was stock on a late model Ranger.
HotWheels
Twilight Zone
B&M 10" hi-tek cooler. $189 summitt racing.
BroncoJAK
:eek: Is that with the fan I hope? Mine measures 10x7x1.25. Brackets are just riveted on. Ranger at work totaled, so I snagged it for nothing.
HotWheels
Twilight Zone
yup Spal fan. Little different than your setup though...still Ranger cooler is nice.
roundhouse
I just ordered the full rubber mat from LMC, but I think I am gonna go to a big rig salvage yard, and the the foil insulation blanket from a Cabover tractor, and install it under the rubber mat,
If I ever had the body off, I would definitly install it underneath.
ALso coating the floor in bedliner helps alot,
I used Hurculiner, and then when I swapped trans I had to make a new tunnel cover, and the new one is not coated yet, and after 30 miles its so hot you cant hold your hand on it, but the part that is covered with hurculiner is warm, but touchable.
