heat reduction
kilron
Portage. PA
What does anyone think of removing the fresh air intakes by the windshield frame and putting little electric exhaust fans under them. What about putting holes in the wheel wells and putting a little sheet metal about 1" above the holes as a splash guard, only doing it from the top of the wells.
broncow72
Village Idiot
Spring,TX.
Do you have a scoop on the hood? Try this link to see a nice clean way to help vent the engine bay.http://www.americanbronco.com/page3.html
BroncoJAK
I've seen people add vents from a boat on to their hood. I picked thse up from a dealer on ebay. 9"x5" stainless for about 20 with shipping.
joser
Chesterfield, MI
That's exactly what I was thinking this week! I have heard so much about what happens to the wind after it hits the windshield at speed, it starts to counter act vents in the hood. So, I thought if you put fans pushing up through the vents, it would always vent the engine compartment.
I think this would really help in slow speed situations where you are not getting the airflow at road speeds. This is something I am going to try soon.
BroncoJAK
I intended to install mine Friday at work where all my tools are, but ram out of time. For some reason this lady thought it was more important I put her car back together. ?:?
coachbarnes
Franktown/Breck, CO
If you want to reduce heat in the cabin, here is a terrific article -- using a '71 EB. http://www.4wheeloffroad.com/brandpages/ford/131_0306_heat/
Opening up the wheelwells is the best way to remove engine compartment heat. If you're running headers, wrap them.
GRIZZLY
Lakewood, CA
Have you wrapped yours? I was told that they would trap moisture and promote corrosion. I don't know if I can buy that because within the first 5 minutes of starting your engine the moisture would be cooked off. My next project is going to be wrapping the headers and part way down the exhaust and putting heat shield Dynamat under the carpet. My wife burned her foot last year where there was a hole in my old carpet. I never noticed because I always wear boots.
So as not to hijack too far I have Scott's (American Broncos) perforated fenders and they definitely brought down my under hood temps. Fairly straight forward to install too. The die grinder is your friend....
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
Venting the heat
Heres some pictures of my 20 dollar cure.
Underhood tempuratures are now controlled
TOFIC
coachbarnes
Franktown/Breck, CO
I've got the wrap, and it's going on as part of a restore -- as well as on the racer. I first saw it on a racer earlier this year, and the owner sold me on it - he's had 'em wrapped for 3 yrs - no problems, and he saw a significant reduction in heat. So he says, and I believe him enough that I'm covering up some shiny new ones!
TOFIC
Redcliff Alberta
BoltBuster said:
walker I like the idea but how do you keep the rain and mud, sand out?
Well have to admit I have not had the mud and sand problem, but the snow and rain do not seem to affect this setup. The only thing I can say about it is the holes in the vent are small enough that anything getting into the engine compartment just disappears.
The one thing I have noticed is when I am moving the air exiting the vent keeps most stuff out.
TOFIC
GRIZZLY
Lakewood, CA
Thanks...
kilron
kilron
Portage. PA
This is not a remedy purely precautionary....and thanks for all the good input, what do you guys think about the wheel well vents with a pusher fan above the vents in the upper wheel well
TOFIC
Redcliff Alberta
popsbronco said:
What kind of screening is that?
Neet idea.
It is 1/8 inch thick screen. It is called 63 percent void round hole screen. Mine happens to be steel but it is available in Aluminium. Call Bob at Accurate Screen in Calgary (www.accuratescreen.ca) and tell him you saw it on the Bronco site. He will help you out.
TOFIC.
popsbronco
Edmonton Canada
TOFIC.
Thanks again for your help
Walker949 ;D
74bronc
there is no doubt that wrapping headers will reduce heat but there isn't a header manufacturer on planet earth that will warranty a set of headers that have been wrapped. They might know a thing or two about the stuff so I would call and ask before I wrapped them up
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
Removing the air intakes work well, according to people who have done it. The fans shouldn't be neccessary as the air pressue under the hood is higher than the pressure infront of the windshield. Hot air will exit thru these vents at both high and low speeds. Fans may help but shouldn't be needed.
