Heater valve
bushman
Oregon City, OR
I bought a 1969 recently that was stripped down to, apparently, run in the 1970 Baja 500, so it doesn't have a heater. I am installing it now, but my brother says there is supposed to be a bracket that holds the water valve in place. Does this make sense? I can't find any evidence of this, but I want to build this thing correctly.
wildbill
Old Bronco Guy
:cool: :cool: :cool: The heater valve is in the hose under the hood and has a cable hooked to it. Its like if is just there no brackit holding it just the cable good luck and have fun.:cool: :cool: :cool: Bill :cool: :D :p
TJK74
Newark CA
Just hooks up to the cable like this
No bracket holding the valve in place. Just resides in the water hose between the intake and the heater core.
airman
If you have a tough moving cable keeping it stationary may hep you operate the valve better. I had to tie mine down to get it to close all the way (which still leaks).
I put in the shut off vlave from BC's for the summer. Made a huge difference. The last time the water valve leaked I eliminated it and have not put one back in since. But I plan to soon.
MOLLEY
PARKER CO
just a note i had a valve that did not close all the way and that was the cause of a over heating problem i chased that trouble untill the next winter and i opened the valve for heat and over heating went away .. its always something .
airman
Molley, I am not sure but I wonder if you have a water pump pumping the wrong direction or a thermostat installed backwards. Or has the bypass hose been plugged off or eliminated?
I have a valve installed to completely block the water to the heater core. I have never had an overheat problem.
By the way, my wife went to high school in Parker.
Sorry for the thread thievery.
bluebronco69
Damascas, OR
i dont have the bracket holding it down, and mine works fine, since the hoses were stiff they keep the valve pretty well in place, if its not holding make a bracket outa some angle and attach it to the intake manifold. HTH
