Heim joint steering
rubbman
So I need some ideas for mounting a steering stabilizer onto my heim joint steering! Any pics would be appreciated( I am running a 1-3/8" stone crusher setup)!
bronconut73
I think Duff sells that set up. I bet they can hook you up.
You could likely still use the stock brackets with very minor modifications.
If you prefer something different without getting too exotic, Rancho still sells their kits with lower mounts where one end clamps to the axle housing and the other to the main tie-rod (like bigj's parts do) and would likely be less expensive as well.
Probably as many ideas as you can imagine.
The good news is that you can still drive the thing without a stabilizer shock. The other good news is it shouldn't be too hard to wrangle one in there somehow.
Good luck. Let us know what you end up using.
JWMcCrary
Here's a pic that is several years old. Stone crusher steering with a procomp stabilizer using the stock brackets. If I remember correctly I had to open up the holes on the bracket that attaches it to the steering and bend the ubolts slightly, very tight but it worked. I took all that off when I changed to ram assist.
