1buckeyefan1
- Sep 21, 2017
- 632
Sorry for the long post.. i'm at wit's end today and really need your guys help to troubleshoot further..
So i've been shaking down my 74 w/ a 2001 Explorer 5.0 and 4R70W swap.. in hopes of getting it to paint this fall..
I drove the 2001 Explorer around before i tore it down and it shifted/drove great. 122k on the odometer at the time. I just did the basics to the 4R70W.. dropped the pan, changed filter, cleaned it up.
I got the Bronco running earlier this year and miraculously, it ran/drove great at the initial start. I did some other body work and really got it going the last few months. I've driven it 4-5 miles and it drove/shifted great.
A few weekends ago as i was backing it into the garage, i noticed a howl/grinding noise as I was shifting in/out of reverse. I quickly shut it down. I drove it a few more times and nothing. It's starting to do it a little more.. only when shifting in/out of gears, usually between P-R-D
So today I decided to try and fix a leak on my D20/AA ZF adapter before I took it in for exhaust. I started by draining the transmission so it didn't splash all over when I pulled the transfer case. Got it all put back together, topped off the Dana20 and the Transmission w/ fluids and went to start it up.
Not only is the noise louder now, but I can't get it to go into any gear! I pulled the transmission pan and checked for a dropped filter, shavings, and watched the indents as my daughter shifted through the gears. All seems fine.
But now the noise is even worse.. almost like you're grinding gears on a manual transmission. It almost acts like it wants to go into gear (revs up), but nothing.
Even more odd is that I can't shift the dana20 when the transmission is in neutral. It grinds the transfer case, as if the transmission is still spinning???
I'm going to be up all night searching through forums.. and have all day to troubleshoot tomorrow. But im afraid to shift through gears to avoid further damage??
Thanks in advance!
Thanks in advance!
