If the transmission is not in park, the output shaft will spin unless something stops it. Usually that something is the rear tires being attached to the ground. However, if the transfer case isn't connecting the trans output to the driveshaft that output shaft will spin.
There is a possibility that the input gear of the tcase could have been installed backwards. This would give no high range on the rear axle. It would act just like it was in neutral if the levers were in rear high. You wouldn't be able to drive it though until you engaged the front axle in high range.
So I had a chance today to install my longer lokar shift linkage rod. I tried a couple of different configurations, but got it locked in almost the only way it works.. and got the trans arm at 7:30 like the lokar instructions mention.
So I found that the only way to guarantee full park (pawl engagement) is to adjust the lokar linkage so the full 4r70w park is pinned to the 'lock' on Park on the flaming river column. If I adjust it past the FR column lock, it has a little slop and doesn't always fully depress the pawl. So basically, I have to 'latch' the full compression of the pawl via FR column lock on P. I originally had P on the transmission a little left of P on the column, you could ever so slightly move the column lever to the right and pull the pressure off the pawl. This has been adjusted and I have visually confirmed that the detents for the gears work correctly. My gear indicator on the column is off once I get past N, but I'll worry about that later.. pretty sure it wasn't going to line up with the 4R70W in the first place.
I tested it out and am still getting the pawl grind. A repeatable scenario is when I start in Park (pawl engaged) reverse, come to a complete stop, then try to go into park, then I immediately get the grind.
I'm 99% confident that this is because the output shaft is still spinning somehow, even though I'm completely stopped. I'm pretty sure this points to an issue with my transfer case not fully in gear or something that is allowing the output shaft of the 4r70w to keep spinning while I'm trying to engage the pawl?
I tested it out in 2-low and it worked for a bit, but then I eventually got the grind as well. Whenever I shifted into gear (R,D) in 2l, it jumped, leaving little tire marks)
I still do have a pretty high idle.. I'm chalking it up to still needing the 02 sensors hooked up.. but I'm hesitant to install the exhaust if I still need to take the transfer case off.
I'm at wits end here. I can't understand why I can move forward, backwards, etc (in 2h or 2L) But then the output shaft is still spinning when I come to a stop? I'm not 100% sure I didn't put the transfer case back together correctly.. but it doesn't compute that I can put it in motion if the transfer case is allowing the output shaft to spin?
Attached video is of my putting it into Park and the pawl fully locking. After latching/unlatching at least 20+ times, i'm pretty confident the pawl is doing its job. But it can't engage (grinds) when the output shaft is still spinning??
