Help ! Auto Column Problem
Zeke
Help!!!
I was putting on my body lift and forgot to loosen the auto column linkage at the trans. I heard a "pop" when I lifted the body (the shifter being forced "in gear").
Now, the shifter doesn't want to stay in "Park". I have adjusted the linkage. Did I break something internal in the column?
Thanks,
Zeke
Viperwolf1
electron whisperer
Either there or in the tranny. Disconnect the linkage and see if you can shift the gears on the trans lever. That should narrow it down.
