Viper,
Thanks for that link! There is a ton of info in there that I am gonna go through. There is no substitute for knowledge. ;D
On another front, messed with the engine today and HAPPY to report that it is running ALOT better! It is still heating up pretty quick though and the idle could come down a bit but overall it is much better than it was.
Turns out that the timing was out by a tooth on the dizzy. Learned alot today once I got a chance to play with it. Was nice to hear the engine Rev a bit finally. ;D Still gotta break in the cam so I didn't go too crazy but it sounded good. However, once I reconected the spout connector it didn't seem to run as good. %)
In process of fabbing up a shroud for the radiator. That should remedy most of the cooling issues hopefull as currently there is nothing surrounding the fan. Also, is it possible to install the thermostat backwards and it still opens?
Not sure if mine is opening or not at this point. Thinking of switching to a 180 but will stick with the 195 until the shroud is completed. Hopefully tomorrow.
Overall, a good day just gotta get the idle lower and Finish the shroud! ;D
Thanks again Viper and the others for all your help with getting this figured out. I would say im probably about 85% there!
