gambling209
- Apr 20, 2010
- 198
make sure that your truck motor has a roller cam. not all do. no pro to add, just need some extra parts. changing your rocker to 1.7 from 1.6 movers the power band up. not sure that is what you want. going with and aftermarket cam with bigger lift will mean new springs in the heads. if on the cheap. run the stock h.o. cam. if you buy most any after market cam, might as well get one custom ground. about the same money. don't go too big. you will regret it.
