I just replaced a large majority of my braking system on my 1977, but the brakes are soft to nonexistent. Can you all help me decide where to start my trouble shooting efforts? Here is what is new:
1. rear drums and all associated hardware
2. wheel cylinders
3. Brake lines steel and rubber
4. New front disc rotors and pads
5. Master cylinder (replaced this when I bought the vehicle and it worked prior to my efforts. I did not adjust anything here so I do not think this is the culprit)
Here is what is original (old):
1.Power booster (this worked before and I did not touch it so I doubt it is bad)
2. Proportioning Valve
3. I rebuilt the calipers per the tech articles listed on this site.
Once I installed all the new parts. I bled the brake lines starting at the rear passenger wheel, then rear driver, then front passenger and finally the front driver side wheel. I saw no air bubbles so I thought the system was bled properly. I did not pull out the brass nipple on the proportioning valve when I bleed the front wheels as I was told by a very experienced and seasoned bronco enthusiast that it was not necessary. The pedal went from soft to firm so I thought job done, right? After I applied the brakes for the first time with the vehicle in motion the brakes went soft.
I am thinking that I must have a leak somewhere and air is getting in, but I cannot find it. So where should I start? One thing that does not seem quite right is that the caliper is not real tight on the bracket that holds it. The key and "spring" thing just pushed right back in by hand. Should I replace the caliper key spring, or is this normal? The Calipers are on correctly (ie. bleeder screw up).
2. wheel cylinders
