Help with 5.0 EFI Donor List
MattM
Missoula, MT
Can you guys help me with this list? I've tried to compile a list of 5.0 donor vehicles from past posts. Please feel free to add more and/or correct my mistakes.
Thanks for the help.
Vehicle
a) Standard Output or HO?
b) SD or MAF
c) Cam
d) Parts List
e) Notes
’96 to ‘97.5 Explorer/Mountaineer
a) HO
b) MAF
c) roller cam
d) RJM Harness, Mustang computer, ’89 to ’93 Mustang EFI, Mustang dizzy, Flywheel?
e) Best Choice - with RJM harness and A9 computer. So one of the common tricks is to drop on older harness (RJM is a perfect use here as it is all new but drops on and hooks up to the old computer stuff). This gives you the best flowing intake, best accessory drive and the most common harness, computer, etc. that are all easy to hook up. This motor has early GT40 heads (not GT40P heads) and an internal EGR (good things). Throttle body and injectors both work.
’97.5 to ‘01 Explorer/Mountaineer
a) HO
b) MAF
c) roller cam
e) Explorer motor newer than 5/3/1999 will need a new fuel rail. Work as well but the heads are a little weird and like to burn spark plug wires on the exhaust (spark plug angle changed on the "P" heads). plugs are angled weird. causing fitment issues.
Accessory drive is the one to get. compact, good alternator and power steering pump. Fits a Bronco very well and the clutched cooling fan is the best thing for cooling the engine. The intake is the best of the mass produced 5.0 intakes.
Downs; the "P" heads have an odd spark plug angle. They will work but not with a lot of the headers on the market. Some work (I don't keep a list). Also the Bronco manifolds will work with some clearancing. The next up is the EFI. Total pain to deal with the new OBD-II stuff. Fuel tank pressure, fuel tank temperature, fuel level, 4 O2 sensors and cats. All has to be there and working just like it was in the Explorer for everything to be happy. Good news, the older, simpler and less finicky Mustang EFI will work on the engine.
’87 to ’88 Mustang
a) HO
b) Speed Density
c) roller cam
d)
e)
’89 to ’93 Mustang
a) HO
b) MAF
c) roller cam
d) Maybe nothing ???
e) The most desirable computers and factory harnesses.
’94 to ’95 Mustang
a) HO
b) MAF
c)
d)
e) Harness and intake are a bit different. The '94/5 mustangs are just a touch different. They can be used as is, converted back to '93 and prior with harness etc. You can even use the new harness with an older computer by moving a half dozen wires at the computer side.
’87 Crown Vic/Grand Marquis
a) SO
b) Speed Density
c)
d)
e)
’88 to ’90 Crown Vic/Marquis
a) SO
b) Speed Density
c)
d)
e)
’91 to ’93 Crown Vic
a) SO
b) Speed Density
c)
d)
e)
’89 Lincoln Mark VII
a) HO
b) Speed Density
c)
d)
e)
’88 to ’90 T-bird/Cougar
a) HO
b)
c)
d)
e)
’91 to ’93 T-bird/Cougar
a) HO
b) MAF
c)
e)
Mercury Capri?
a)
b)
c)
d)
e)
Viperwolf1
electron whisperer
All explorers were HO and used a roller cam just slightly less aggressive than the mustang HO cam. The later explorers had some EFI connector changes so the standard RJM harness connectors may not work.
