quick I need help...best donor for efi swap?
Dr. Awsome
Provo
I did some searching and I couldn't find what I wanted. I'm sure it's in there some where but ther's so much. I'm going to moving to cali for the summer to intall security systems and I need to do an efi swap befor I go for gas milage reasons. What i'm wonering is what is the best car to get a motor out of?
I've found plenty of info on how to do it but more would be great.
What problems am I going to run into?
Any idea of how much it will cost?
What should I look for good and bad.
Thanks in advance!
77B
Bixby,Ok.
efi swap
I am currently installing efi into my 77EB. I got a sweet deal on an 91 HO roller motor out of a Mercury Cougar XR7. The most complete and comprehensive information I have found is at www.fordfuelinjection.com
There is loads of information along with shopping lists for different budgets. Hope this information helps you as much as it has me. "Thanks Ryan"
Good luck ;D
Dr. Awsome
Dr. Awsome
Provo
I'm currently reading all that info. I printed it out and i'm slowly working my way through the book.
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
You read it twice. Ryan is the man when it comes to EFI.
I have read that stuff several times and still get loads of info off the site.
MANY THANKS Ryan you have filled in many a boring day when I was recovery from my heart attack
TOFIC
PS you want the mustang EFI years are on the website.
Dr. Awsome
Dr. Awsome
Provo
last night and today I have read through all the stuff he has on his sight as well as everything he wrote for the bronco dirver article. I have read it all 3 times to be correct and I have highlighted all or atleast most that I have found to be improtant.
lars
Been here awhile
NorCal flatlands
Best?
"Best" depends on how you define it. At this point for me it would mean a MAF SEFI setup modified to work with the 426 stroker I'll have someday, including a chipped A9L, etc, etc, etc. good for 500HP or so. Meanwhile I'll make do with the stock Mustang-style EEC-IV MAF SEFI that's running pretty well on my 5.0 Explorer motor.
If you are retrofitting to a stock 302 with no mods, then a speed density setup off an older non-HO Crown Vic will run nicely and will likely be a lot cheaper to buy and install than any of the Mustang stuff. With scrounging you can probably do it for 300 bucks or less. It'll run upside down, give good fuel economy and throttle response, and though the speed density setup doesn't handle engine mods very well, it's a good match to the stock EB 302.
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
I've read somewheres that there are a few applications that put the pulleys and accessories closer to the block than most, leaving more room for a goodly sized fan 'tween the water pump and the radiator. I don't know all the specifics of this but I think T-Birds and Econolines are good for this
